flywheel spins, engine does not.
Old Feb 25, 2009 | 04:28 PM
Slopetruck's Avatar
Slopetruck
Hi. I have a 91 1 ton with an auto transmission. The starter turns the flywheel but not the engine. D o I need to remove the tranny to see what is going on? Any ideas?
Old Feb 25, 2009 | 04:54 PM
jas88's Avatar
jas88
Uh, if you are sure the flywheel is turning, then you have a broken crank. Are you sure the starter gear is engaging the flywheel? If not then you would get a real fast "wheeeeeeeee" noise from the starter but the engine would not turn.
Old Feb 25, 2009 | 05:01 PM
Slopetruck's Avatar
Slopetruck
Yeah, the flywheel is spinning. I can wiggle it back and forth too.
Old Feb 25, 2009 | 05:41 PM
AREA 51's Avatar
AREA 51
transmission out, hope it's just a flywheel has the transmission been out before?
was it running ok then just wouldnt restart or did it stall and wouldn't re-start?
Old Feb 25, 2009 | 05:56 PM
Slopetruck's Avatar
Slopetruck
I had it in the shop a year ago and they had the tranny out for a rebuild. I was driving down the highway and the rpm's started jumping around. I pulled off and it wouldn't engage in any gear. I shut it down to check tranny fluid leaks and level which were good. When I went to start it again the starter would just spin the flywheel but wouldn't crank the engine.
Old Feb 25, 2009 | 05:57 PM
Slopetruck's Avatar
Slopetruck
the engine never stalled, I shut it down.
Old Feb 25, 2009 | 06:01 PM
AREA 51's Avatar
AREA 51
i would be seeing them real soon.
do you have your paperwork? did they replace a rear main seal? maybe the bolts were not torqued and sheared the bolts off.
Old Feb 25, 2009 | 06:18 PM
Slopetruck's Avatar
Slopetruck
I no longer have the paper work, and I do not know if they replaced the rear main seal or not. Wouldn't the crank spin if the flywheel was spinning?
Old Feb 25, 2009 | 06:25 PM
AREA 51's Avatar
AREA 51
not if the bolts that hold the flywheel to the crankshaft are broken
Old Feb 25, 2009 | 06:42 PM
Slopetruck's Avatar
Slopetruck
Gotcha, thanks for your help. No way to do it with the transmission in it looks like.
Old Feb 25, 2009 | 07:02 PM
AREA 51's Avatar
AREA 51
nope sorry
check out the "injection pump?" thread
i feel your pain! lol
Old Feb 25, 2009 | 10:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I have heard of the flex plate hub breaking loose from the flywheel.
So the problem may be you new a new flex plate (flywheel), and the hub is still bolted to the crank like it should be.
Old Feb 26, 2009 | 01:59 AM
AREA 51's Avatar
AREA 51
[quote=Dave Sponaugle;7191297]I have heard of the flex plate hub breaking loose from the flywheel.
So the problem may be you new a new flex plate (flywheel), and the hub is still bolted to the crank like it should be.[/quote
i'm sure that's it.
does it have a 2 piece flywheel with flex plate like on the 6.9? not sure i have only had a 6.9 with automatic apart.
if so the converter should be still connected to the crank?
none the less, transmission out and a junk yard item to fix.
Old Feb 26, 2009 | 10:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
there is a small plate that is supposed to be mounted on the outside of the flex-plate to prevent the flex-plate hub from cracking. if this was not put back on when the flex-plate was removed, the hub will break off the plate, causing the symptoms you are describing.
Old Feb 26, 2009 | 02:34 PM
jas88's Avatar
jas88
Wow, I never heard of that. Better than a broken crank, tho.
