Oil Coolers?
Old Feb 25, 2009 | 03:48 PM
Baja16's Avatar
Baja16
Oil Coolers?
need some advice...
I've got a 96' F-250 with a 351W that im currently rebuilding (the motor). When i took the oil cooler off the block i noticed that the side that faces the block is pretty rotted and the groove that the o-ring sets in is almost gone... It needs to be replaced but when i called Ford they said it lists for around 250plus tax... Is their any aftermarket company's making replacement ones? Dont really want to get a used from the junkyard with a brand new motor. I would like to use the factory setup, using the engine coolent but if you guys know of any alternate ways lets hear it... thanks
