I had this same problem on a Chevy Z-71 pickup that I owned way back before I switched to Ford. (no need for any Chevy haters to send me emails)
Anyway, I had the loud rattling sound, at idle, that you appear to be experiencing.
I allowed my exhaust system to cool then I crawled under the truck and started banging on different areas of the exhaust system. I just hit these areas with my fist, but I think a rubber mallet would work just fine.
I was carefully listening for any loose connections, vibrating parts, etc.
When I hit the cat. convertor it rattled and sounded like bits and pieces of something were broken off inside of it.
I took the truck to the muffler shop. They cut off the old cat and installed a new one.
The mechanic brought the old cat to me and shook it. It was rattling like crazy.
However, we are talking about a Ford here. Broken cats is a common problem on 3/4 tone and 1 ton Fords, but on half tons, not so common. Not saying it doesn't happen, but I have not dealt with too many cases of failures. The sound is more likely coming from the heat shield.
There are 4 converters on most F-150s, a front pre converter, and a main converter. It is more common for the pre converters to break apart and get blown back into the rear converter, but if this was the case, you would probably be experiencing a severe loss of power.
With your code, I suspect you need to clear out all the EGR lines and replace the EGR sensor.
That's why I suggested allowing the exhaust system to cool then crawl underneath and started lightly banging on everything to see if the cause of the rattle could be found.
It very well could be a loose heat shield.
I was just telling the original Poster about the cause of the same rattling problem I had that he is experiencing.
It does happen though, had to have the driverside (both) replaced cause I broke everything loose inside. And BearRiver isn't joking about the loss of power. How I managed it is beyond me as it was before I set it up for and started taking it off road. Had them replaced and good as new
