Fuel Leak....Need help!!
Old Feb 25, 2009 | 11:53 AM
m300636's Avatar
m300636
I recently bought a 2000 F550 Dump Truck with 67,000 miles. It has a small fuel leak with residual diesel fuel showing ontop of the engine block. During idle I noticed it dripping about every 20 seconds or so from a plastic nipple located on the back side from where the fuel filter is. The nipple is adjacent to what appears to be a fuel line (steel line connected with a rubber hose) coming in next to it. I am a rookie and first time owner of a 7.3 and was hoping someone might no what is causing this and how to fix it?
Thanks,
JIM
Old Feb 25, 2009 | 12:05 PM
guzzle92's Avatar
guzzle92
Fuel drain valve leak. Common and an easy fix.
Here is my writeup on how to fix it.
Old Feb 25, 2009 | 12:06 PM
superduty4x4's Avatar
superduty4x4
Simple fix, you need to change the O-rings in the fuel drain valve. There is a how-to on guzzle's site.
Edit- Bob beat me to the punch
Old Feb 25, 2009 | 01:02 PM
m300636's Avatar
m300636
You guys are awesome...thanks!
JIM
Old Feb 25, 2009 | 02:31 PM
afonda's Avatar
afonda
If i understand ... this is common to happen with big swings in ambient temperature, specifically to the cold side.
this happened to me on the first cold snap last year. I havnt fixed it yet but it quit leaking on its own.
I bought the o-rings from guzzle though. I just need to put them in.
Old Feb 26, 2009 | 05:35 AM
m300636's Avatar
m300636
Fuel Leak
Yeh, that is a good point. i just recieved the truck about 3 weeks ago. The dealer drove the truck from PA to CT. It was very cold then...I had it checked out the day of delivery by my local garage and they picked up on the residual fuel atop the motor. It has since warmed up but the leak continues.
Good luck on the fix...it appears to be pretty simple.
Old Feb 26, 2009 | 06:47 AM
Supercab's Avatar
Supercab
Wink
The fix is really quite simple, just follow Guzzle's dirrections, and pictures, I just recently did mine, and I used HIS VITON "O" rings-they are better designed for use with todays ultra low sulpher Diesel fuel, the PO of my truck had the whole drain valve replaced at a Ford dealer for just over $250.00 parts and labor, I ordered 2 sets of the VITON "O" rings from Guzzle and they were $3.00 each, and acording to what I have heard the VITON will last much much longer than the original "O" rings--first time out take your time and follow the dirrections and you will be fine, If I can do it you can!! Good Luck!!
Old Feb 26, 2009 | 08:33 AM
aldridgec's Avatar
aldridgec
Does anyone think there is a real point to the blue orings guzzle offers? I mean for $6 if it's better right? I need to get some either way, and I think most go with the viton.
