Sponsored by: Real Truck
What Batteries
Old Feb 25, 2009 | 10:22 AM
endobear's Avatar
endobear
What Batteries
Time to replace the original batteries in my 02 F350.
What would you guys recommend I get?
Old Feb 25, 2009 | 11:12 AM
cartmanea's Avatar
cartmanea
Interstate
Old Feb 25, 2009 | 11:45 AM
brian42's Avatar
brian42
Veteran: Navy
Optima Red or Yellow Top...
Old Feb 25, 2009 | 11:50 AM
Eng1Driver's Avatar
Eng1Driver
In your post you say your truck has the factory battery in it. Since it's almost seven years or older I would think another Motorcraft battery would be a safe bet.
Old Feb 25, 2009 | 11:57 AM
madjak's Avatar
madjak
endobear,
Welcome to FTE!
I would say either the Motorcraft or the Interstate. Just be sure to replace both of them.
Check out the 1999-2003 7.3 forum below. Lots of good info on your truck.
Old Feb 25, 2009 | 01:03 PM
tex25025's Avatar
tex25025
I have the Red Top and it's been good for me.
Old Feb 25, 2009 | 01:06 PM
cartmanea's Avatar
cartmanea
Unless you do a lot of offroading and rockcrawling, I don't think the cost of Optima batteries is justified. I picked up a set of Interstate MTP-65 at a local tractor supply store for $87 each. Its hard to beat Interstate in quality and longevity.
Old Feb 25, 2009 | 01:08 PM
tex25025's Avatar
tex25025
If you run alot of electronics too, that'll cost alot of electrical output. Especially if you run alot of aftermarket sound system and something that isn't power efficient like a CB, that'll suck it out of the regular ones.
Old Feb 25, 2009 | 04:27 PM
fordman8's Avatar
fordman8
I've had good luck with NAPA batteries.
Old Feb 25, 2009 | 06:00 PM
brian42's Avatar
brian42
Veteran: Navy
Only if the engine is off. If the engine's running then the alternator supplies the juice...
Old Feb 25, 2009 | 06:02 PM
endobear's Avatar
endobear
Thanx for the advice.
Shes my toy hauler and dosnt see much off road action so Ill probably skip the Optimas.
Old Feb 25, 2009 | 06:09 PM
tex25025's Avatar
tex25025
That's not enough depending on your setup. I don't have a CB(never really liked them but that's not relevant), so I don't have something that is totally inefficient, but what I do have is something that definately is draining with just one alternator when everthing is on(lights, radio(not the basic radio either Pioneer avic-z(or something like that, I'll have to look next time I'm at the truck)), amp(2 of them, one for door speakers other for sub), gauges, dashdaq) I get 14v on the Optimas, when I was using the bare minimum batters I was getting barely 13v, and both of those were on fresh batteries and one alternator. At first I thought the alternator wasn't up to snuff, but after I put in the Optimas(almost 2 yrs ago) it's held that charge, unless something else was going on only thing I could think of was the first batteries weren't up to snuff.
Old Feb 25, 2009 | 06:29 PM
powerstroke72's Avatar
powerstroke72
Motorcrafts here.
Old Feb 25, 2009 | 07:05 PM
unrulee's Avatar
unrulee
I've had an Optima red top in my 79 for about three years and couldn't be more impressed, it got the truck fired off when it was around zero and the truck hadn't been started in a month. I'm sold on them. They're more money up front, but are supposed to last longer (I have yet to find that out).
Before next winter the '05 PSD is going to get yellow tops in it.
Old Feb 25, 2009 | 07:07 PM
cartmanea's Avatar
cartmanea
The Optima batteries charge and discharge differently than liquid lead-acid, so comparing voltage at full charge doesn't really tell you much. If you are wanting something to support a lot of steady current draw the yellow top is better than the red top, but then the high cranking amps of our engines will kill the yellow top faster. I'll stick with Interstates and spend about 40% as much as for new Optimas.
