Wiring relays.
Old Feb 25, 2009 | 06:19 AM
KevinC.'s Avatar
KevinC.
Wiring relays.
In my distribution box I am adding a maxi and a relay, I have the Maxi taken care of and legs 30 and 87 on the relay done as well. Now 85 is my ground and 86 is to the ignition. On 85, do I ground it to the frame or is there a ground rail somewhere like in a house circuit panel that I am overlooking somewhere? I don't want to gounnd it to frame if there is a way to keep it more factory looking. And when wiring 86 is there an ignition wire under the hood or do I have to piggy back into a wire under the dash? If so does anyone know which wire?
Thanks,
Kevin
Old Feb 25, 2009 | 11:55 AM
KevinC.'s Avatar
KevinC.
Or do I ground the relay to the pump then to the frame? I'm stumped right now
Old Feb 25, 2009 | 12:18 PM
Neal 97 250's Avatar
Neal 97 250
I would just take it to a good ground on the frame or engine.
What kind of pump are you referring to?
Old Feb 25, 2009 | 12:44 PM
KevinC.'s Avatar
KevinC.
Electric fuel pump. I am going to ground the pump to the frame but should I ground the relays ground to the frame also?
Old Feb 25, 2009 | 01:26 PM
Hussler's Avatar
Hussler
Kevin, frame or engine ground is your common ground for everything, so yes, you can ground the relays ground to frame or run it to pump and ground it there. Your call.
Old Feb 25, 2009 | 01:32 PM
KevinC.'s Avatar
KevinC.
Ok, for the relay leg that goes to the ignition, where do I hook that one?
Old Feb 25, 2009 | 02:11 PM
Hussler's Avatar
Hussler
You probably want it to be hot on both start and run, correct? I think I would just tie it into ignition side of fuse #22.
Old Feb 25, 2009 | 02:47 PM
KevinC.'s Avatar
KevinC.
Oh ok that makes sense. I am wantin it to be hot for run and start, but I am not using #22, I'm adding its own fuse from an open spot for the pump, but I can do the same on that one I guess. Ok its all coming together. I wanted to be sure on everything before I took it apart and couldnt get it back together. Thanks.
Old Feb 25, 2009 | 11:46 PM
joe_13894's Avatar
joe_13894
I hope you don't mind the hijack of the thread:
What was involved in adding more fuses to the box? I've been considering some additions, but I hadn't taken a look at this part yet.
Old Feb 26, 2009 | 06:58 AM
KevinC.'s Avatar
KevinC.
You have to buy a spare Fseries fuse box from the junkyard. Take it apart to see how it works and you will have to use the metal connectors inside it.
It's really simple, actually really cool how they designed it. The relay is where I got stumped, figuring out where they all go.
Old Feb 26, 2009 | 09:02 PM
joe_13894's Avatar
joe_13894
Thanks Kevin
Old Feb 27, 2009 | 07:15 AM
KevinC.'s Avatar
KevinC.
Thanks for the reps, hope it works for you.
Reef Tech
Electrical Systems/Wiring
Oct 7, 2014 08:57 PM
TheKirbyMan
15
Dec 5, 2010 11:26 PM
TheKirbyMan
'80-'86 FAQs (Frequently Asked Questions)
900rider
Jun 2, 2005 06:26 PM
FORDPLA
Apr 18, 2000 06:01 PM
