will engine components and glow plugs
Old Feb 25, 2009 | 02:50 AM
whiskeyflip's Avatar
whiskeyflip
will engine components and glow plugs cross with 6.9 and 7.3. I have a 93 f-250 7.3 and dropped a valve split a piston and I found a 6.9 until I rebuild the 7.3{costly} It doesnt have the glow plugs in it{6.9} can I use the ones out of my 7.3?
Old Feb 25, 2009 | 04:01 AM
LCAM-01XA's Avatar
LCAM-01XA
Take your entire 7.3 glowplugs system, and bolt it up to the 6.9 - I can't think of anything essential the 7.3 has that the 6.9 does not. While you're at it, transfer the fuel filter assembly from the 7.3 to the 6.9 as you really wanna have a water separator. If you have an E4OD transmission and the 6.9 does not have provision for a tachometer sender, you will have to transfer the IP gear housing from the 7.3 to the 6.9 as well.
Old Feb 25, 2009 | 09:43 PM
Dave Sponaugle's Avatar
Dave Sponaugle
whiskeyflip,
Welcome to FTE and the IDI diesel forum.
If you split a piston, there is a very good chance the block is cracked.
Old Feb 25, 2009 | 10:16 PM
whiskeyflip
it was at an idle and not under load the sleeve is still in good shape it was split not destroyed.
