Electrical problem w/brake lights
Old Feb 25, 2009 | 04:31 PM
TRIKSTR's Avatar
TRIKSTR
Every so often the fuse for the brake lights blows. I've stripped the wiring harness from the brake lights to the firewall. Didn't find any bare spots.
While on a trip I used the Emerg. flashers for a few minutes and the fuseuse blew. Can a flasher relay go bad and cause problems?
Not looking forward to tackling the wiring underneath the dash.
Old Feb 25, 2009 | 10:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Do you have a trailer plug in on the back?
Those are probably where 90% of the brake light problems are located.
Also another place, since the turn, brake and 4 way flashers all use the same filament in the rear lights, brake power goes through the turn signal/4 way flasher switch.
So the next place to look could be in the turn signal switch.
Bad flasher could be possible, but that usually means no flash instead of blown fuses.
Old Feb 25, 2009 | 10:30 PM
ford trans tech's Avatar
ford trans tech
the fuse powers several items ,they will be listed on the facia panel
