multiple ?'s
Old Feb 24, 2009 | 08:48 PM
stokedguy's Avatar
stokedguy
Exclamation multiple ?'s
i was wondering how hard gp are to replace on a 97 250 i have done some mods with the help of all of you. but i would like more info on the bb mod and shimming and where the h*ll is this stuff located i am new to diesels i'm pretty good with cars but all the abrev. are driving me crazy. also when i floor it it will up shift could that be a problem with the tps
thanks brian
97 250 cc sb 6637 straight piped ts chip rebuilt e4od
Old Feb 24, 2009 | 09:07 PM
helifixer's Avatar
helifixer
glow plugs are about 30 minutes unless someone has installed other than Motorcraft beru plugs, just remove valve covers remove wires from glow plugs, spray base of plugs with carb cleaner to rinse the oil away and then blow with air to dry the carb cleaner( you don't want any liquid in the glow plug hole or you will hydraulic your engine and bend the rods). remove plugs install new ones. check valve cover wiring harness at all connections for burnt wires and burnt plugs. if none are burnt re install.
Old Feb 24, 2009 | 09:11 PM
helifixer's Avatar
helifixer
as for the bb mod it is put under the spring of the fuel pressure regulator A couple guys have pics of it and hopefully they will show up soon and post them up. a note when installing the bb clean the spring with brake cleaner or carb cleaner and dry it with light air than stick some Vaseline on the end of the spring to make the bb stick to the spring, this way you know it makes it in the right spot.
Old Feb 24, 2009 | 10:14 PM
stokedguy's Avatar
stokedguy
thanks helifixer where excatly is it located is it on top driver side of the fuel filter????
Old Feb 24, 2009 | 10:21 PM
helifixer's Avatar
helifixer
directly above the schrader valve on the left hand side of the fuel filter.
Old Feb 24, 2009 | 10:22 PM
oldbird1965's Avatar
oldbird1965
It is located on the side of the drivers side of fuel filter towards the front. Its a cylinder looking device, unscrew it and the spring is behind it. Put the BB hehind the spring like helifexer said. Helifexer, if you can change GP's in 30 minutes then your an excellent wrencher!!
Old Feb 24, 2009 | 10:36 PM
helifixer's Avatar
helifixer
33 years wrenching, 15 on helicopters. after working on helicopters these trucks are wide open and easy to work on. helicopters aren't. for example front engine mount bolt on a bell 412 up to 12 hours for a mechanic to install! and you almost always pull the twin pack so that means 2 mechanics for 12 hours, on on each side.
Old Feb 24, 2009 | 11:30 PM
oldbird1965
WoW, I'm impressed! To do the GP's woud take me a couple of hours. It's like that sign that hang's in my mother-in-laws kitchen. I'm not a fast cook, I'm not a slow cook, I'm a half fast cook.
Old Feb 25, 2009 | 01:48 AM
Gobstopper909's Avatar
Gobstopper909
stroked guy, dont worry about setting time records. take your time with the gp's. if they start to bind up while you are unscrewing them,, STOP!!!! spray with with your favorite loose juice. then proceed. not trying to scare ya about tackling this project, but just want others to learn from my gp mistakes. good luck
Old Feb 25, 2009 | 08:06 AM
helifixer's Avatar
helifixer
Defiantly heed Gobstoper909's advice on taking your time. a stuck plug and being in a hurry makes for a long project (removing head to get broken glow plug out). I go fast until it comes time to pull the glow plugs than it is slow and easy.
Old Feb 25, 2009 | 03:28 PM
cowmilker08's Avatar
cowmilker08
If you are wondering about the signatures just look where it says welcome, username, go straight over to the left side of the window, down a little and click on 'User CP'. this is the user control panel. you can adjust and modify your browsing experience from the link. on the left side of the window after you click and the next page loads there is a menu, and a link called 'Edit my Signature' or something along those lines.
Oh yeah welcome to ...
Old Feb 25, 2009 | 05:50 PM
heathrunkles's Avatar
heathrunkles
For the sig's to work I beleive you have to have 25 or 30 posts or something like that. Unleess thats changed with the other stuff
Old Feb 25, 2009 | 06:49 PM
250turbo's Avatar
250turbo
all good advise above,slow & easy. weclome to fte!!!
kurt
Old Feb 25, 2009 | 08:13 PM
stokedguy's Avatar
stokedguy
thanx for all the help i think that it might be the gpr. i crossed the to big lugs on it this morning for about 30 sec and it fired right up. it was about 75 in CO today and it had to crank for 10- 15 sec sitting at work from 6 am and lots of white smoke none this morning it sat all night without being pugged in it was about 25 last night
