Bizzarr electrical issues
Old Feb 24, 2009 | 08:06 PM
Hiflyer746's Avatar
Hiflyer746
Best as described to me. . .
02 auto. . . door ajar light has been on for some time now. Therefor issues with radio turning off. . . dome lights and the likes. Not sure if that issue is related to the most recent. Driver says "while driving sometimes lights on the dash will flicker. . . sounds like a relay underneath is clicking. . . will often kill the motor. Sometimes the motor won't die. . . but it seems the guages quit working or at least very unreliable. . . they jump around and the throttle doesn't respond. Just idles. Had to cycle the key to get things working again."
I havn't looked any closer than pulling codes which i'll display below. . . but this looks like a relay or power to a relay going bad. What do you guys think? Many of the codes are related to cruisecontrol, throttle B switch, parking brake switch. . . . stuff like that. Really random. So here are the codes that appeared after a KOER switch test:
P1536, P0220, P1780, P0571, P0703, P0565, P0566, P0567, P0568, P0569.
Here are the general diag codes shown:
P0381, P0500, P0470.
So. . . what do you guys think?
Timmy
Old Feb 24, 2009 | 08:12 PM
megawatt00's Avatar
megawatt00
I'd check for a loose ground Timmy. The symptoms sound like a ground that is faltering. If it wasn't for the engine almost dying Id look at the VSM some of the symptoms point to that except for the engine issue.
Old Feb 24, 2009 | 08:14 PM
Hiflyer746's Avatar
Hiflyer746
Yeah thats a good idea. . . where are some major ground points on here?
Timmy
Old Feb 24, 2009 | 08:17 PM
megawatt00's Avatar
megawatt00
Battery to block and there are 1 or 2 that go from the block to the frame/body. If the chassis grounds go the electronics are not happy.
Old Feb 24, 2009 | 08:23 PM
Hiflyer746's Avatar
Hiflyer746
Ahh this will be fun. . .
Timmy
Old Feb 24, 2009 | 08:29 PM
megawatt00's Avatar
megawatt00
Good Luck!
