Cylinder head flatness
Old Feb 25, 2009 | 07:43 PM
Wyatt66f100's Avatar
Wyatt66f100
Originally Posted by Maxium4x4
Blown gaskets are a result of the head bolts stretching or bolts that turned right out in your hand because they were never torqued at the factory. My heads were twisted and bowed, so we machined both heads and installed studs.
I can truly tell you if any machined head were going to blow again I would have already done it. I see no one mention they checked the block, you should also consider this when doing the repair.
i stand corrected. im just saying it could happen cause higher pressure does cause the bolts to stretch with the head lifting. but yeah your right.
Old Feb 25, 2009 | 07:50 PM
Maxium4x4's Avatar
Maxium4x4
I see your point Wyatt if using torque to yield bolts, I recommend and know this isn't possible on all dealer repairs, head studs.
For any do-it-yourself, buy the studs.
Old Feb 25, 2009 | 08:01 PM
Wyatt66f100
yep yep what he said. ^^^^
sometimes ill recommend them sometimes i wont. it all depends on the customer. if i think hes going to take the studs to far and go with more mods such as a chip cause hes over excited then i wont say anything. but ill say yes for a work truck that needs it if the guy or gal has a good head on his shoulders. cause if they get over excited ill just see the truck in within the next couple of months cause he or she put too much extra money into it in all the wrong places you know?
Old Feb 25, 2009 | 08:05 PM
Maxium4x4's Avatar
Maxium4x4
Those torque to yield bolts make great paper weights.
Old Feb 25, 2009 | 08:08 PM
Wyatt66f100
yep they make good fanny scratchers when you cant figgure a truck out too. lol
Mountain Mudder
Jul 17, 2010 08:00 AM
ford4x4956
Jun 14, 2010 07:08 PM
00excdiesel
Apr 20, 2008 06:38 AM
adharvey2
Dec 21, 2007 04:46 PM
afinepoint
15
Jan 25, 2004 04:11 AM
