4WD problems
Old Feb 24, 2009 | 09:48 AM
eprn1n2's Avatar
eprn1n2
Angry 4WD problems
After replacing the front axle I took it out for a test drive this morning. It was fine in two wheel drive. I tried the 4WD and it seemed to be fine. The problems started when I tried to get out of 4WD. It would not revert to 2WD. It shuddered and the tires would chirp. I was finally able to get out of 4WD by backing up. Any clues as to what is happening? There is fluid and the locking dial is in auto
Old Feb 24, 2009 | 12:11 PM
ingman's Avatar
ingman
Check the tech folder. I have found that with mine they will unlock after shuting the truck off. I'm not abig fan of these hubs, but it is very nice to just turn a ***.
Good luck
Old Feb 24, 2009 | 12:26 PM
dchamberlain's Avatar
dchamberlain
When you flipped the switch from 4WD to 2WD did the 4x4 indicator light go out right away or only after you backed up?
If there is too much tension on the drive train, the transfer case simply cannot release the gears. This is really a normal symptom of using 4WD on a hard surface and backing up to relieve the tension was the proper thing to do. It has nothing to do with the hubs. The hubs won't try to unlock until the transfer case indicates to the computer that the transfer case has indeed shifted out of 4WD.
Old Feb 24, 2009 | 01:28 PM
eprn1n2's Avatar
eprn1n2
I recall that the light went out right away. It seems that the problems started when i got onto the pavement like the previous poster said. Things might be normal.
Old Feb 24, 2009 | 08:54 PM
Ricohman's Avatar
Ricohman
If you ran it for a bit in 4wd on pavement it may not want to unlock as its bound up.
Find some gravel or dirt and do a figure 8 or jack up one front wheel to realese the tension.
Old Feb 25, 2009 | 08:06 AM
eprn1n2's Avatar
eprn1n2
The problem is that I have never used a 4WD truck before and have nothing to compare. From your imput and others I have spoken to my 4WD is functioning properly and that's good news.
