help transsmition problem
Old Feb 24, 2009 | 08:20 AM
alan18's Avatar
alan18
hi i have a 93 f150 with the 5.0 and the e4od transsmition when i go out and drive the tuck while it is cold it will shift through all of the gears on its own but as it starts to warm up i have to start shifting manualy but when it hits operating temp i only have first and second gear help!!!!!! plz
Old Feb 24, 2009 | 10:26 AM
alan18's Avatar
alan18
plz help!!!!!
Old Feb 24, 2009 | 11:05 AM
jroehl's Avatar
jroehl
Have you checked the fluid with the engine hot, idling in park, on a level surface? What was the level? What was the color when you put it on a white paper towel? Does it smell burnt? Have you pulled any diagnostic trouble codes? Have you checked the wiring harness(es) for loose connections, wear points or potential shorts?
Jason
Old Feb 24, 2009 | 01:49 PM
alan18's Avatar
alan18
thank you for responding
i have looked at the trannsmition fluid level and it was on the perfect line it did not smell burnt but i will have to look at conections but highly unlikely cause we had went through the motor and wires a little while ago but i will check anyway
Old Feb 24, 2009 | 02:00 PM
jroehl's Avatar
jroehl
Codes?
Short of any trouble codes, I would start leaning towards a pump and or torque converter problem, like my F250 has. When the fluid is cold, it's thicker and builds pressure more easily, but once it warms up and thins out a bit, the worn pump and/or TC can't push it to the pressures it needs to have. That, or you have some valve body or solenoid issues (seals and such), that respond to the same fluid temperature differences.
Jason
Old Feb 24, 2009 | 02:16 PM
alan18's Avatar
alan18
i have not been able to get any trouble codes yet i do have a computer but it will not give me any codes i know that i do have a very extreamly slowwwwwww tranny leak but i keep a eye on that i have not had to add any tranny fluid yet do you also know if there is a blow off valve on the tranny the one day i was hauling with it i accidently left the overdrive on and when i pulled over there was a constant line of fluid pouring out of it i put more fluid back in and then i drove home i looked at it the day after and i could not see where it was coming from
Old Feb 24, 2009 | 03:29 PM
quicklook2's Avatar
quicklook2
drain pan, replace filter with a ford filter, drain convertor, use quality fluid.
this is where you should start.
Old Feb 24, 2009 | 04:50 PM
Supercab's Avatar
Supercab
Wink
I absolutely agree with changing the fluid and filter!!! DON'T HAVE IT BACK FLUSHED!!!!
Just do it the old-fashioned way, drop the pan, replace the filter, drain the converter, and add MERCON V synthetic fluid, you will have about $75 bucks in this, and I think you will be OK......
Old Feb 24, 2009 | 05:04 PM
alan18's Avatar
alan18
now when i first had this problem i imeadiatly changed the fluid and the filter but i used dextron 111 is this a worthy fluid or do i drain and try again
Old Feb 24, 2009 | 07:28 PM
1966Tbird's Avatar
1966Tbird
that's probably what ruined your tranny i would definatly drain it as fast as possible and put in mercon V fluid
Old Feb 24, 2009 | 07:48 PM
jroehl's Avatar
jroehl
He probably just got the name confused and meant "Mercon III/Dexron", which was the original spec for that tranny.
Jason
Old Feb 25, 2009 | 09:46 AM
alan18's Avatar
alan18
well thank you all for responding i will try all of your guys options and i will get back to yall
Old Feb 25, 2009 | 02:38 PM
alan18's Avatar
alan18
before i dig does anyone els have any more ideas
the tranny does have 176000 on it
Old Mar 15, 2009 | 11:57 PM
fordguy2009's Avatar
fordguy2009
i drained mine, torque converter as well, new filter, 16 qts. mercon v... still the same. although,, there was a lot of metal on the magnet and throughout the pan. looked as if it was never changed. does not slip, once in gear, just has trouble shifting. ..?? ( overdrive works)
Old Apr 2, 2009 | 09:02 AM
alan18's Avatar
alan18
see now when i did the tranny flush you know drain the fluid and filter and put new in i cleand off the magnet and cleand everything but the tourqe converter i was having this problem about two weeks before i had done the flush i thought that it might fix the problem but it didnt i still have yet to take tourqe converter out but i plan on doing that soon
