1996 f250 ?
Old Feb 23, 2009 | 08:54 PM
aderondaksnowremoval's Avatar
1996 f250 ?
how can you tell if your cat converter is plugged up ? also can you eliminate the egr ? been trying to figure my truck out cause some days it runs great and certain days it wont run right at all ,bogging down not shifting right lack of power and sometimes clears out then crapy again. i posted my problem before but not many feedback any help out there plz thnak you . it has new plugs,wires,cap,rotor,airmass sensor,temp control sensor for computer ,still no change thnaks again
it has 351 w e4od trans
Old Feb 23, 2009 | 09:56 PM
1966Tbird's Avatar
1966Tbird
cut the exhaust off and look into the cat with a light is all i know if it's not clogged put a band clamp on and look elsewear
Old Feb 23, 2009 | 10:11 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Does the cat rattle when you tap it? Bad cats will do that. If it does not, do what 1966Tbird said and cut it off to take a look. Leave the EGR hooked up. They sell kits to eliminate, but they cause check engine light problems. There are no performance advantages to removing it either.
Before going any further, check the codes and see if that finds anything.
Old Feb 24, 2009 | 01:33 PM
there are 3 diff cat on it . when i went out plowing last night i unplugged the air mass sensor and the egr vaccum line and cut the muffler off and it ran alot better but there is still a little bog to it . i looked in the cat before the muffler and i only see the screen looking thing like bees nest. this problem is driving me nuts thanks for the info all . is there any info on what i wrote above thanks
Old Feb 24, 2009 | 01:39 PM
quicklook2's Avatar
quicklook2
you use a vacuum gauge to check for clogged exhaust.
also, patience is a virtue, you will get an answer to your questions if you just wait a bit.
some forums take 5+ days to get back to you.
fte is much faster but not instantaneous.
Old Feb 27, 2009 | 10:04 AM
f250?
can you change a e4od to a c4 or c6 trans cant find any info on this . and if so what do i need to do? thanks all
Old Feb 27, 2009 | 03:55 PM
BigBlueOx's Avatar
BigBlueOx
also a tell tale sign of a clogged "cat" is it will glow cherry red hot when driving down the road. Not so much sitting at idle.
Old Feb 27, 2009 | 05:22 PM
himatnite's Avatar
himatnite
blueox is right about it glowing cherry red. sometimes after it's gotten that hot, you can catch fire. seen it happen. but, from everything i've read about it, your cat is clogged. might as well change it out. heck, they even have scrap value. i think they're worth about $30 scrap. that'll help with your cost of buying a new one.
esebm
Escape & Escape Hybrid
Aug 18, 2010 09:39 AM
FarmingFord
Jun 2, 2009 10:40 AM
justinsinternet
3.8 & 4.2L V6
Apr 12, 2005 09:03 PM
gfe76
Garage & Workshop
Jan 19, 2004 12:32 PM
I_Thnk_Ford
Oct 19, 2003 01:02 PM
