Sponsored by: Real Truck
Fog Light Help
Old Feb 23, 2009 | 08:41 PM
FlyCanadianGuy's Avatar
FlyCanadianGuy
Fog Light Help
I hate to ask questions that have already been answered in another forum, but after countless searches I cannot find a good answer/picture. I am looking for the relay/wire that runs from the factory switch on my dashboard (headlight switch, pull OUT to turn on fogs) and goes through the engine bay and to the actual foglights themselves. I purchased my truck used, the fog lights are there but NO WIRE actually going to them. Im assuming aftermarket lights were used, then replaced with factory before selling the truck. And help would be appreciated and pictures would be very helpful! BTW, my vehicle is a Canadian truck with Daytime running lights, and when I do finally get these things hooked up to the factory switch, I will want to get around the high beam/no fog problem.
As a side question, how come I cannot view the for sale forum?
Old Feb 24, 2009 | 09:59 PM
FlyCanadianGuy
Any ideas?
Old Feb 25, 2009 | 05:57 AM
Maxium4x4's Avatar
Maxium4x4
I moved you up here to SuperDuty, maybe the guys will have an answer for you since they are a resourceful bunch.
Old Feb 27, 2009 | 09:03 AM
aaronbrace's Avatar
aaronbrace
There is a small harness on the driver side of the truck in the engine compartment. It is a simple 2 prong connector. I cannot remember exactly where it is but I found it underneath the truck.
My truck came without foglights and the harness was there along with the relay. All I had to do is replace the headlight switch with the one that pulls out for fogs. I then connected the fogs to the already run wireharness in the engine compartment and I was done.
If you still need this info, let me know, and I will get under mine and locate it again. Maybe take a picture.
---Aaron
Old Mar 1, 2009 | 11:56 AM
FlyCanadianGuy
TY Aaron, I will definately poke around once I have time. Work is crazy busy right now.. :S
Old Mar 2, 2009 | 07:31 PM
tycham's Avatar
tycham
Where did you get the switch that included fogs and was it for a OS HD
Old Mar 3, 2009 | 11:51 AM
aaronbrace's Avatar
aaronbrace
I am not familiar with the term OS HD.
It was the switch assembly that was for autolamps+fog lights. My truck came with just autolamps and no fogs.
I ordered it from the y2kfordparts guy on this forum.
Mine is an 05.
Old Mar 3, 2009 | 12:36 PM
tycham's Avatar
tycham
I mean the OBS o(old body style) F250 HD (heavy duty) I want to retain as much of the factory look/function as possible
GamerGirlAlice
Aug 4, 2013 10:24 PM
billpinsc
Mar 10, 2009 05:02 AM
Ronin007
Escape & Escape Hybrid
13
Jun 2, 2007 09:16 PM
pickupman2002
Jul 11, 2006 09:26 AM
