Sponsored by: Auxito
intake??
Old Feb 22, 2009 | 10:44 PM
rickapalooza's Avatar
rickapalooza
intake??
ok heres the story got a 99 f150 with 5.4 3 days later engine went so new engine but had 2 swap intake...now the truck runs good but today i put er down 2 the board a bit playin in the snow. when i stopped there was antifreeze comin out my exhaust.....as in green liquid drippin on the snow and a decent amount,,,,so im curious anybody see this even drove home after this and thats an hour on the highway..no prob runs fine normal temp and all..no coolant leaking at all.....my question is it just at full throttle the vac is pullin coolant from intake????they used the ol gaskets for intake swap....what yall think????no oil in coolant or coolant in oil....curious bout opinions ill pressure test it 2morrow and go from there....
Old Mar 6, 2009 | 01:13 PM
projectbad78's Avatar
projectbad78
they used the old gaskets!!!!???!!!!! thats your problem
Old Mar 6, 2009 | 01:39 PM
racerx6466's Avatar
racerx6466
x2
Old Mar 6, 2009 | 01:52 PM
n5926g's Avatar
n5926g
X3
Old Mar 6, 2009 | 03:00 PM
Spotty's Avatar
Spotty
Some guys think those newer type rubber band gaskets can be used over. Some can, in certain applications. I would NEVER re-use one on an area as critical as an intake. Take a look at one when it is new... it's not flat as a pancake like they look when you pull something apart. Also.. did they follow the torque pattern when they tightened it? Too bad a short cut like that equals a do-over. Good Luck in getting it fixed.
Jeff
Old Mar 6, 2009 | 03:12 PM
racerx6466's Avatar
racerx6466
Yeah on something like a oil pan or trans pan, but intake gasket falls into the same category as reusing a head gasket
Old Mar 6, 2009 | 04:44 PM
projectbad78
who did this? a shop or a friend?.......you prob will overheat on a 1 hr drive b/c youll be losing coolant and pressure
Old Mar 6, 2009 | 08:36 PM
rickapalooza
ive been babyin er and no loss of coolant..no heatin up at all but im doin the gaskets anyway i think just under the vac draw of hard acceleration its pullin it out of the water jackets.n i agree ...i was pissed when i found out they reused the intake gaskets...this is my work that did the job....i am a bodyman and the painter but our mechanical end is a joke mechanic comes to me for advice all the time...long story ive just never seen it where the antifreeze is comin out exhaust was curious if any1 seen this....im sure its the intake...ive done mechanical for years and should of just did this myself as i am from now on like i used to...
Old Mar 7, 2009 | 09:51 AM
chaser1602's Avatar
chaser1602
Will they let you paint there cars?
Old Mar 8, 2009 | 05:41 PM
rickapalooza
lol always do maybe its time i start forgetting to prep them right so paint flys off at the car wash ha ha....
Old Mar 9, 2009 | 01:37 AM
projectbad78
ive never had one of these intakes off, but i took off my throttle body yesterday and i was lookin and is there even water jackets that run thru the intake like older engines?
Old Mar 9, 2009 | 05:09 AM
chaser1602's Avatar
chaser1602
Yup.Still has to cross over to circulate
Old Mar 9, 2009 | 07:53 AM
BLK94F150's Avatar
BLK94F150
I think it goes between the #1 and #5 cylinder. If it's leaking into one of those, you're risking a blown head gasket and an expensive fix. That's what happened to mine when the intake manifold gasket failed.
Mike
Old Mar 9, 2009 | 08:27 AM
Spotty's Avatar
Spotty
I know on my Mustang with the 4.6 it crosses over at the front between #1 and #5 ( as mentioned by Mike). My intake basically blew where the plastic crossover on the front of the intake cracked. I lost all my coolent in about 1 minute. That's not related to this problem being discussed, but I do know the intake carries coolent from one side to the other. Any breach in the gasket would allow coolent to get into the intake. What I don't understand here is why it is not burning it and showing up at the tail pipe as white smoke? If it was a massive internal leak MAYBE it would drip out the pipe, but that's a LONG way to go with out being burned up by something. Plus he claims his coolent level doesn't go down much? Doesn't make sense to me. If it's pulling from the water jackets that is head gasket related, not intake related. If it started right after the intake was installed, I can't understand how it could not be front crossover related. Either way I would not ignore this, you can do some serious damage with large amounts of coolent getting into the combustion chamber. Good Luck...and keep us informed.
Old Mar 9, 2009 | 09:30 AM
BLK94F150's Avatar
BLK94F150
I have the cast crossover on my 2000 5.4, but the stock gasket failed on leaked coolant into cyl #1 and engine = boom!
With that much coolant coming out of the pipe, I don't see how it could run right or hydrolock for that matter. I wonder if flooring it after the overhaul might have just caused some crud to get flung out of the exhaust that was just sitting there under normal pressure and it just happened to look green like antifreeze?
Mike
