running light problems
Old Feb 22, 2009 | 09:06 PM
TDELONG83's Avatar
TDELONG83
I have an 04 f250. the cab lights, mirror, and dash lights all work, but the tail lights and front park lights will not work. all of the lights are on the same 15 amp circuit. anyone have any idea where i should look for a short
Old Feb 22, 2009 | 09:10 PM
uofmgriz's Avatar
uofmgriz
maybe the towing harness? that's one thought...
Old Feb 22, 2009 | 09:27 PM
bismic's Avatar
bismic
This may sound goofy, but I read a post somewhere about a headlight or taillight bulb that burnt out, actually shorted out inside the bulb, and caused similar problems.
Old Feb 23, 2009 | 04:07 PM
TDELONG83's Avatar
TDELONG83
thanks for the replys. I checked the trailer plug and had power. I will check the blubs next. thanks again
Old Feb 23, 2009 | 05:09 PM
bismic's Avatar
bismic
Please keep us informed!
Old Feb 23, 2009 | 07:03 PM
wiingnut's Avatar
wiingnut
check the grounds
Old Feb 23, 2009 | 08:18 PM
uofmgriz's Avatar
uofmgriz
I've got a Chilton for our trucks that has the wiring diagrams in the back, fortunately by trade, I'm an electrician and know how to read them. I'll check it out per the manual to see if we're missing anything and I'll get back with you.
Old Feb 23, 2009 | 08:50 PM
uofmgriz's Avatar
uofmgriz
OK, according to Chilton, that line is fed from Fuse 7 (15 amp) in the power dist. box. It then goes to the Main Light Switch (Tan/Wht is the line, and Brn is the load; essentially to the lights). I would check at the Main Light Switch to make sure that you don't have a loose connection or a bad switch.
The book also shows a multi function switch (inwhich case I have to do more digging to find), but it also feeds some of these lights and the instrument panel turn signals. If you have those lights, then I would seriously doubt that your problem is here.
Hope this helps you some.
Old Feb 24, 2009 | 07:51 AM
TDELONG83's Avatar
TDELONG83
I don't think it is in the switch as i have part of the lights working. the only lights that have no power is the park lights. I also have power to the trailer plug. I am going to pull the four lights and housings to check for burnt wires. Thanks for all the imput
Old Feb 24, 2009 | 08:01 AM
69cj's Avatar
69cj
While you have the assemblies out, take a new bulb and rotate it to each light to make sure that you don;t have a shorted bulb. Long shot but the disassembly labor is already done.
Old Feb 24, 2009 | 07:37 PM
uofmgriz's Avatar
uofmgriz
one other long shot, Chilton shows the license plate lamps tied in the circuit...maybe toss an eyeball at them. Sometimes it's the seemingly innocent that causes the most ruckus.
Old Feb 27, 2009 | 04:08 PM
TDELONG83's Avatar
TDELONG83
I checked the bulbs and all were good. I gave up and took the truck to an auto electric shop today. I will let you know where he finds a problem. Thanks for all the help
Old Mar 3, 2009 | 03:58 PM
TDELONG83's Avatar
TDELONG83
just an update. I drove the truck to the auto electric shop, and he thought it was in the fuse block. Now he has the truck to a point that it will not even turn over or attempt to start. now i have to have the truck towed to another garage. I guess he may be a electric expert, but knows nothing about the diesel. Lesson is make sure you take your truck to a reliable diesel shop.
Old Mar 3, 2009 | 05:22 PM
69cj's Avatar
69cj
I hope he's willing to pay for part of the repair.
Old Mar 3, 2009 | 08:08 PM
uofmgriz's Avatar
uofmgriz
That REALLY sucks!! I'm with CJ...he'd better be coughing up some dough to fix what he screwed up!
