Gear installation price..
The difference is in the hub. Notice and remember that the 9 inchers that you are familiar with have no hub, they have an axle and flange that suppoerted the weight of the vehicle. You cant remove the axle without taking the wheel off, and the axle itself has the lug nuts attached directly to it.
9 inch axle semi float:
Now look at your D60 rear, and notice the large hub and the 8 small bolts that retain the axle to the hub. easy to identify. Also the drum on a full floater cant be removed like a semi float axle. The hub assembly has to be removed. Unlike the semi float axle where it just slips off. (exception is the ff 10.25)
#2 WMS, is the distance between the mounting surface of the left hub to the mounting surface on the right. You are simply looking for the same width of the wheel mouning surface. Because there are hub differences, you cant use the backing plate, nor can you use the total with at the hubs. These may be different even though the wheel mounting surface is the same. If you want your tires to stay in the samemounting location, this is a very critical measurement. May need a friend to help hold a tape measure.
#3 How to tell if you have a locker or junk carrier? Good question. While I can tell just by looking at so many over the years, explaining over a keyboard can be a little tough. The main reason is because the traction devices fit inside of the big old carrier.
In many cases it requires the removal of the carrier and it might have to be opened up to determine what is in there.
In any case the open two piece carrier is very desireable, and the Detroit simply plops right in the place of the cross and spider gears. Simple as that to install.
Here is a Gov Lok as viewed from the inside when the carrier is opened up:
im going to hunt some stuff down, ill take mesurements and pictures and get back on here so i can make sure im getting what i need..
again, thanks a lot.
theres a salvage yard i stopped at today during work and they said they have a 14 bolt from a 97 2500 thats full floating 8 lug. is this the 10.5" ring?
would this have disk or drum brakes?
is there a web site where i can get a break down of this axle so i know what year trucks have what in them(long shot but worth a try)?
I believe this axle that you have found will still have drum brakes and will be suitable for you.
Check here to see years and models these axles were found under. These pages help with not only identification for the GM axle, but fords and others as well.
Decent info and seems to be accurate.
AMC Differentials, Chrysler Differentials, Dana Spicer Differentials, Ford Differentials, GM Differentials, Suzuki Differentials, Toyota Differentials,
i wouldn't normally ask but another salvage yard has 4.56 14 bolt now and if it has a locker, it could save me some money i think lol.
Here is the thing, buy it if it is in one piece and not all tore up. Then once it is in there, drive it. Hit the road in 2wd and see how you like it. believe me, if it has a locker, you will spend most of your time in 2wd anyway. Once you get a chance to drive it, you decide if it is appropriate or not. If the truck digs it, then you are gold, and you pretty much got everything for free. Just have to change the front to match and you are in like Flynn.
This sounds like a great deal waiting to happen, and can save you some big cheddar.
You're hitting on a ton of great questions I have (and will have in the future).
I'm bookmarking this puppy!!!
Did I provide a bad link???? Maybe I should consider another source.
Have you a pic of the diff? real easy to tell, even with just a pic.
