Fuel Line Stuck
Old Feb 22, 2009 | 07:11 PM
Jasher20's Avatar
Jasher20
Fuel Line Stuck
I'm in the process of replacing the fuel line on an 02 7.3 and I can not get the large one to detach with my quick release tools. I've bought 3 different tools...an aluminum one, and two different plastic one's as well. It is a 3/8 if memory serves correctly. The line has an odd bend right where it goes into the female end. Anyone dealt with this and have suggestions other than keep trying?
Old Feb 22, 2009 | 07:40 PM
Orezona's Avatar
Orezona
Where are you talking about? I don't remember bends.
Old Feb 22, 2009 | 07:58 PM
adamzelazowski's Avatar
adamzelazowski
First check fuel tank before you took fuel line off ADAM
Old Feb 22, 2009 | 08:09 PM
adamzelazowski
https://www.ford-trucks.com/forums/7...hen-hot-3.html
Old Feb 22, 2009 | 08:16 PM
Jasher20's Avatar
Jasher20
I've done the fuel tank and that went fine...sorry I did not specify. I am disconnecting the fuel line earlier in the system...under the alternator and the plate there is a disconect and that is where I'm trying to get it undone. The fuel tank disconnect was easy, this one is not so much.
Old Feb 22, 2009 | 08:33 PM
adamzelazowski
Soory i didnt now Thank you
