backlights not working
Old Feb 21, 2009 | 09:53 PM
trutxn's Avatar
trutxn
when i push the brake pedal my brake lights dont work. checked the switch on the pedal , not the problem.
what else could i check??
Old Feb 21, 2009 | 10:11 PM
79f2506.6L's Avatar
79f2506.6L
what is the model,year of said truck
Old Feb 21, 2009 | 10:13 PM
kshaneh's Avatar
kshaneh
mine did the same thing i ran a new wire to the + on brake switch and it worked fine after that
Old Feb 21, 2009 | 10:38 PM
kingford72's Avatar
kingford72
do your turn signals and parking lights work at the back of the truck, if not it could be a ground issue since they both use the same ground if the parking lights work but the turn and brake lights don't then you could have a turn signal problem since the brake lights go through the turn signal switch first before they go to the back of the truck, if the turn signals work and the brake lights don't, then check the brake pedal switch again
Old Feb 21, 2009 | 10:41 PM
kshaneh's Avatar
kshaneh
mine did that none of the lights in the rear didnt work after a couple days i found 2 bad fusible links and 2 blown fuses and 1 bad ground
Old Feb 21, 2009 | 10:52 PM
kingford72's Avatar
kingford72
Yeah that too LOL
Old Feb 21, 2009 | 10:54 PM
kshaneh's Avatar
kshaneh
yea durn wire gremlins
Old Feb 22, 2009 | 10:59 AM
trutxn's Avatar
trutxn
1979 Ford f100 truck
All the lights work in the back except the Brakelights.
Bought a new switch, made no difference.
Will check positive and ground wires again.
All suggestions appreciated.
Old Feb 22, 2009 | 11:40 AM
kshaneh's Avatar
kshaneh
on mine it did the same after i fixed the fusible links and repaced the fuses, it fixed the tail lights except the brakes. so i tested the + on the brake switch had power but they still didnt work. what i ended up doing was running a new wire to the hot side of the switch and it took care of it.
Old Feb 22, 2009 | 05:20 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
When you turn your hazard light switch on, do they flash in the back?
Old Feb 22, 2009 | 06:04 PM
kingford72's Avatar
kingford72
I never had to go back any further in the system that the brake switch on the pedal that is the first thing in the brake light circuit. check for positive 12 volt on one of the brake switch wires then check your fuse, dont forget to check your test light on your battery first ( yeah ask me how I know )
Old Feb 22, 2009 | 09:22 PM
trutxn's Avatar
trutxn
flashers work all the way around.
checked the wires going to the switch that seems to be the problem.
Thanks for all of your help.
