locks wont stop
Old Feb 22, 2009 | 10:44 AM
hazmat456's Avatar
hazmat456
locks wont stop
my locks will not stop the unlock cycling, I disconnected the RAP and the GEM and all five doors one at a time cleaned all connections that I could find with electrical cleaner checked the wire harness going to each door, and replaced the relays, I can't make them stop without pulling the relays in the rear quarter
any advice would be helpful
Old Feb 22, 2009 | 05:12 PM
87 XLT's Avatar
87 XLT
The lock switches ground the voltage from the relays, sounds like you've got a bare wire someplace thats grounding out.
Old Feb 23, 2009 | 03:07 PM
texan2004's Avatar
texan2004
or a bad relay.
Old Feb 23, 2009 | 04:33 PM
hazmat456's Avatar
hazmat456
relays are good, I have now isolated the offending wire and cut it at the relay, the remote will unlock the drivers door only right now all the others work either manually or if I crawl in the hatch that switch still works. I'm going out now to follow the wires through the body to where they splice to go to either front door, I hope I find something obvious!
Old Feb 23, 2009 | 09:08 PM
texan2004's Avatar
texan2004
Just curious how you verified the relays were good.
Old Feb 24, 2009 | 05:45 AM
hazmat456's Avatar
hazmat456
apply 12 volts across the #1 &2 and check for continuity across #3 &4 , should be open check #3&5 should be closed. remove voltage and your readings,should be the opposite. there is a schematic on the side of the relay, the snap is good and strong with no buzzing, they are just doing what they are told to. when I cut the signal wire and they stopped I ran a resistance test to ground and could see the cycling. I found the splice and re soldered the connection , don't know if that was the problem, but everything has been reconnected and is working properly, just moving the wires around might have been enough to fix it I guess.
Old Feb 24, 2009 | 08:10 AM
texan2004's Avatar
texan2004
Hope that got it for you.
Old Feb 24, 2009 | 10:16 AM
87 XLT's Avatar
87 XLT
Good deal, glad you got it squared away.
Old Mar 20, 2009 | 11:13 AM
nutherford's Avatar
nutherford
Question Door problems - '97 Explorer XLT
Speaking of doors, I've got a couple issues on my '97 Explorer. First is the master switch in the driver's door. Apparently its gone bad, so now when I open the door, interior lights don't come on, etc. The worst thing about it is that I've grown used to the beeper telling me my headlights are on. I've left them on a few times and drained the battery. How easy / difficult is it for a mechanical novice to replace the master switch?
Second is the interior door handle on the rear door. My 7-year old pulled it all the way out while the door was locked. I pushed it back in, but now it doesn't work at all. The exterior handle still works fine. Same question, how easy/difficult is it for a mechanical novice to fix that?
Old Mar 20, 2009 | 05:14 PM
texan2004's Avatar
texan2004
Probably best to start a new thred for this but the quick answer to you questions is that it is not that difficult. In both instances, you will have to remove the dor panels. I would try flogging the switch on the driver's door with WD-40 before I pulled the door handle to replace. This oftern works.
Old Mar 20, 2009 | 08:29 PM
nutherford's Avatar
nutherford
Thanks for the response. I'll give it a try this weekend.
Old Apr 24, 2009 | 12:52 PM
nutherford's Avatar
nutherford
Hey - I just wanted to follow up on this. I did have to have the front door switch replaced, and I put a new interior handle on the back door. The plastic teeth in the rear door handle were broken off. I bought the part from Carquest for $13 and found step by step instructions for removing the door panel and replacing the handle online. It was really easy.
Thanks again for your help.
britteasy
1997 - 2003 F150
Sep 4, 2014 10:56 PM
cworley250sd
Jul 10, 2013 10:03 AM
Black 07
2004 - 2008 F150
Jun 1, 2012 04:13 AM
kmbet
Jun 3, 2008 01:44 PM
Troybiltshredder
Dec 28, 2004 12:35 PM
