Sponsored by: Real Truck
Running Really Rough
Old Feb 22, 2009 | 10:01 AM
phifer's Avatar
phifer
Question Running Really Rough
Hi all,fficeffice" /><O></O>
New to the board, my 04 F250, 5.4 started running rough this week (at idle & acceleration). I have changed plugs and o2 sensors with no luck. The exhaust does have a sulfur smell to it when I shut it off. It has 67,000 miles and I was probably leaning toward checking the COPs next. Anyone have any suggestions?<O></O>
Old Feb 22, 2009 | 10:05 AM
senix's Avatar
senix
change fuel/air filters?
Old Feb 22, 2009 | 10:12 AM
phifer's Avatar
phifer
hi Senix, Put on a new filter yesterday, no change
Old Feb 22, 2009 | 10:14 AM
phifer's Avatar
phifer
i will check the air filter now, but its not to old
dougc's Avatar
dougc
Could it be a bad cat converter or O2 sensor?
Old Feb 22, 2009 | 10:30 AM
phifer's Avatar
phifer
The air filter looks ok (almost new). I just changed the o2 sensors. I thought about the cat, but it seem to happen suddenly.
Old Feb 22, 2009 | 10:45 AM
1975StroppeBaja's Avatar
1975StroppeBaja
I don't suppose you've had a check engine light yet have you?
COPs seem to be a good culprit for this behavior from what I've read.
Sorry I don't have much to offer, I'm mainly subscribing to this to see everyone's responses in case I have this problem with my '04 5.4L.
Good Luck!
Old Feb 22, 2009 | 10:51 AM
phifer's Avatar
phifer
no check engine light yet.
Old Feb 22, 2009 | 11:01 AM
dougc's Avatar
dougc
Just checked the WWW--one suggestion was to put premium gas in the tank and go for a long drive at highway sppeds to try and get the accumulated sulpher out of the cat. The other option was to change the cat--I'd try the first suggestions.
Old Feb 22, 2009 | 11:13 AM
phifer's Avatar
phifer
I filled up with premium yesterday. I thought it might be bad fuel at first. I will take it for a longer drive today to see if it impoves.
This is an excelent site, it is full of helpful info and lots of good feedback. thanks to all!
Old Feb 22, 2009 | 11:23 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Pull codes....could still be the COPS, many times it'll set a code and NOT set CEL. I did this on my Lincoln with the COPS. Pulled codes and found one bad coil. I left the scantool installed and drove it around the block and waited till I felt it miss then stopped and rechecked for codes. Found it, replaced the COP and, fixed! I had a spare COP handy.
Old Feb 28, 2009 | 10:25 PM
phifer's Avatar
phifer
Smile
found the problem, it was a COP. Drivers side, closest to the firewall. Thanks to all. Running great!!
Old Feb 28, 2009 | 11:05 PM
Furian's Avatar
Furian
You Keep What You Kill
Another FTE success! I love this website!
Old Feb 28, 2009 | 11:32 PM
1975StroppeBaja
Good deal! Glad to hear it wasn't something off-the-wall. Congrats on gettin it fixed.
