Hello all I need help locating a flywheel for my 61 F100 with inline 6, it is approx 14 13/16 outside dia and has 146 teeth, anyone know of a good source, Thanks
Welcome to FTE
B4AZ6375B .. 146 Tooth Flywheel-Use with H/D Clutch / Obsolete
14 13/16" O.D. (H/D Clutch) / (6) 5/16" pressure plate attaching holes on a 12 3/8" bolt circle.
GREEN SALES CO. in Cincinnati OH has 22 = 800-543-4959.
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
No Ford Dealer or any other obsolete parts vendor has any.
Fits: 1954/64 F100/600 with a 223 I-6.
Fits: 1954 F100/600 with 239/256/272/292 Y Blocks (EXCEPT H/D 292 engine).
Fits: 1955/62 passenger cars with I-6's and Y Blocks
--------------------------------------------------- EAA6384A .. Flywheel Ring Gear-146 Teeth / Obsolete
GREEN SALES has 2.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 800-546-7278.
MCDONALD'S OBSOLETE PARTS in Rockport IN has 2 = 812-359-4965.
KLIMESH MOTOR SALES (former Ford dealer) in Calmar IA has 1 = 563-562-3241.
No Ford dealer or any other obsolete parts vendor has any.
Fits: 1952/64 F100/600 with 215 & 223 I-6.
Fits: 1954/64 F100/600 with 239/272/292 Y Blocks.
Fits 1952/62 passenger cars with I-6's and 1955/62 cars with Y Blocks.
I removed bad trans and bell housing from truck today, what I thought was a flywheel is actually a flywheel/torque convertor combo. Made the mistake of opening, made a big mess. Trans fluid everwhere. So I neeed to know a number for a replacement combo unit as the replaceemt trans I have has more splines on the input shaft. Thanks
1P7950E .. Cover & Starter Ring Gear Assy-Transmission Converter / 146 Teeth / 14.85" in diameter.
I purchased a replacement ford o matic, instead of trying to get the old trans rebuilt. The two trans's are identical except for number of splines on trans input shaft. Any suggestions would be appreciated.
So would it be possible to keep the original transmission and rebuild it? It might be difficult, but it might be impossible to find the right flywheel and torque converter for the transmission you bought.
Correct the flywheel/torque convertor combo is one piece, the problem is that the internal splines do not match the replacement trans I purchaced.
So I either need another combo unit with correct spline count or a flywheel to match the trans torque convertor I have. The number stamped on the bell housing for the replacement trans is PAR-7975-A will that help any. Thanks
Look on the right side of the case below where FoMoCo is cast in an oval code for an ID number.
On the left side, behind the manual control lever, there should be a oval metal ID plate with the trans code on it.
The ID number will start with either I or P followed by two letters, then - then one or two more letters, like this: IP-L or PAZ-E.
