My 2007 f-250 has the tow command brake system, but I have been having problems with it. I thought it was the trailer, but now im thinking its the controller?? The controller will show a "TBC fault" on the dash and the braking system shows its connected then will loose it on and off. there are no wires loose and everything has been checked. the brakes work..but the system is not working and a ford dealer can not clear the fault, it keeps coming back. any ideas, or has anyone seen this before??
thankyou guys... all the help is great! My truck is also out of warranty, but it is going back to the Ford dealer on monday for another diag. check. John, I have not seen that fault yet...but i believe that we are having similar problems by the information in your post earlier. (thanks for the direction to your post, it helped).
to replace the TBC, is that something that can be done myself? if that is what the problem is?
