need leveling help
Old Feb 20, 2009 | 06:12 AM
dixiemudder04's Avatar
dixiemudder04
need leveling help
I have searched and stuck between 2 kits. The auto springs kit with an offset design. What is that going to do oppossed to the hell bent steel design? PLUS I have the bottom bushing coming out of my stuts on both sides, WHERE can I find a bushing? I have called ford and all the other parts stores around here and they all want to sale me the strut. I have 40,xxx miles and they are factory struts. And why are these kits better than just putting a solid piece of steel there? Please answer all the questions to give me some knowledge. Thanks
Old Feb 20, 2009 | 10:24 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Autosprings calls theirs the "Offset Design" because of a rubbing problem they had on the first units they produced. The early early ones (2004/2005) weren't offset and the Coil-over rubbed on the upper control arm while just driving around.
They revised the design and now call it Offset.
All of the other brands (NCD, Hell Bent) copied the Autosprings design. But they are all pretty much the exact same. Just the weld locations seems to be the major difference between them.
no idea about that bushing.
Old Feb 20, 2009 | 04:07 PM
silver05fx4's Avatar
silver05fx4
well i had the hell bent steal one with no problems but when it is jacked up in the air the spindle does touch the spring but not while driving
Old Feb 20, 2009 | 06:06 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
that is normal Silver. My 2.5" does it also. Only when the tire is hanging off the ground though.
did you pick up your 09 yet?
Old Feb 20, 2009 | 06:43 PM
dixiemudder04
so what about the solid steel block?
Old Feb 20, 2009 | 06:52 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
your preference and price
they do the same thing...and you'll find people who swear by both brands. I prefer the AS kit because I have it and their 3" rear kit.
Old Feb 21, 2009 | 08:15 AM
dixiemudder04
alright another question to the mix. I found some 315/70/17 bfg a/t. Will they fit an XL with just a leveling kit? I have aftermarket 17x8 with 4.75 back space. I just dont want them to rub i do some slight offroad driving. Maybe a few bumps but nothing to extreme.
Old Feb 21, 2009 | 12:03 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I think you might have a winner with those. below is a comparison of 35/12.5/17 vs those 315/70/17. Top is the 35, bottom is the 315. The 315 is slightly shorter/narrower than a 35" tire...so yes, unless you have some wicked backspacing, I'd say those will fit rather nicely.
BTW, a 35/12.5/17 will fit just fine on a F-150 leveled 2.5" with OEM rims...it just gets close to touching the upper control arm. if you aftermarket rims push the rim out another 1/2" or so, that would be perfect IMO
Section Width: 12.51 in 318 mm
Section Width: 12.40 in 315 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 8.5 - 11 in
Rim Width Range: 8.5 - 10 in
Overall Diameter: 34.77 in 883.15 mm
Overall Diameter: 34.36 in 872.74 mm
Sidewall Height: 8.88 in 225.55 mm
Sidewall Height: 8.68 in 220.47 mm
Radius: 17.38 in 441.45 mm
Radius: 17.18 in 436.37 mm
Circumference: 109.2 in 2773.6 mm
Circumference: 107.9 in 2740.6 mm
Revs per Mile: 598.2
Revs per Mile: 605.3
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.7 mph 101. km/h
Speedometer Difference: - Speedometer Difference: 1.186% too fast
Diameter Difference: - Diameter Difference: 1.18%
Old Feb 21, 2009 | 02:39 PM
Catmonkey's Avatar
Catmonkey
You have about an 1.5" less offset than the factory rims, so you should not have any problems rubbing the spindle.
Old Feb 22, 2009 | 06:57 AM
dixiemudder04
the wheels stick out past the truck about an 1" maybe 1-1/2". I called 4 wheel parts yesturday and they told me they would rub.
This is a link to my wheels.
Wheelsforless - Custom Wheels - EA589-8877 - Eagle 589 17x8 7/150 (7Lug Ford) - Truck & SUV Wheels - Wheelsforless
And is there anyway i could have some measurements on the blocks? I talked with my dad who has a machine shop and has the stuff to cut me some solid blocks. I need to know where to drill the holes for the studs.
Old Feb 22, 2009 | 09:56 AM
dixiemudder04
I just measured my rear is 9 1/2" and my front is 6 1/2"
Old Feb 22, 2009 | 02:11 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
huh?
and the post above...if I'm reading it correctly, you are going to make your own leveling kit?
I really really suggest you just spend the $69 and buy a kit off eBay. They come fully welded with new nuts and the proper orientation. They'll save you alot of hassle
Old Feb 22, 2009 | 02:22 PM
dixiemudder04
LOL sorry to didnt tell yall what i was measuring. Those numbers are from the rear and front tires. I'll have to go with a 3" kit correct? And i was thinking about making my own, I was going to get the correct circumference and right thickness and tap the bolts. But i may just go with the kit already made. I just dont like the whole welded in pieces.
Old Feb 22, 2009 | 02:37 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
trust me, just buy them
and I also suggest you only get a 2.5". The 3" is goning to make your truck sit butt heavy
Old Feb 22, 2009 | 04:47 PM
ChargersFanInCO's Avatar
ChargersFanInCO
You've a 2.5 leveling kit, and a AAL setup in the rear? Got a pic from the side of your truck? I want to lift mine a little bit.
