what is the highist egt for a idi
Old Nov 4, 2010 | 10:25 PM
1973dieselhighboy's Avatar
1973dieselhighboy
yea i hate looking threw 5 threads about the same thing and i was not trying to make it sound bad *** i am just saying that they are cappable of way more then 1000-1200 degress that everyone swears by and if you run it at 1200 degress for a min it is toast is bull cause it would of never been set from the factory to run that hot
Old Nov 4, 2010 | 10:32 PM
1973dieselhighboy
the idi i had in my 73 before i upgraded to a powerstroke i use to run hard around 1500-1600 degress and 17psi of boost and when i blew up the injection pump i tore the engine down to look at the pistons thinking they would of been shot with the edges melted and maybe lots of cracks but they looked like new and only one had a crack about an inch long and i was amazed there was not one peace after going up the pass the last time, did love the idi
Old Nov 5, 2010 | 06:59 AM
mechelement's Avatar
mechelement
Old Nov 5, 2010 | 08:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have never gone over 1100 degrees in the 88, and 1200 in 02. if it gets that high, i get out of the throttle
Old Nov 5, 2010 | 04:54 PM
rodneywar's Avatar
rodneywar
hypereurtic pistons start melting at 1200 degrees
Old Nov 5, 2010 | 09:41 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Random question.
Is there any way of telling if an engine has been damaged by high EGT's without removing the heads?
Like is it gonna sound weird idling, skip, miss, shake, etc.?
Old Nov 5, 2010 | 10:02 PM
87crewdually's Avatar
87crewdually
Originally Posted by IDIDieselJohn
Random question.
Unless you look in with a bore scope to inspect the piston tops, the only real way of knowing is pulling the heads. All your other symptoms could also be so many other things like injectors, IP, low compression, ect.
Old Nov 5, 2010 | 10:17 PM
starmilt's Avatar
starmilt
missing blowby that puffs in rithem with one cylinder.
They will missand have low compression on the affected cylinders(not all will be melted or scored) unless someone is a complete idiot.
Grown up diesels will pull a liner which you will know immediately from the noise and the water in the oil pan. lol
If a pyro is reading 1480 for any lenght of time, you need a new pyro.
Old Nov 7, 2010 | 08:08 PM
1973dieselhighboy
brand new pyro read the same in my truck as mine did with the powerstroke
Old Oct 2, 2022 | 10:45 PM
The 7.3 and SEG's Avatar
The 7.3 and SEG
5th Gear
Originally Posted by chubyboy
according to others on here, pistons begins t opit and melt a little over 1200 hundred so i think under 1200 u should be ok.
highest egt I've seen on mine has been 1260 & mines been fine, that was while climbin a hill & trynna maintain 70. Stock na 7.3 e4od 4.10s
Old Oct 4, 2022 | 12:50 AM
genscripter's Avatar
genscripter
chubyboy chubyboy is offline
Last Activity: 11-17-2011 01:54 PM
Old Jul 9, 2024 | 01:14 AM
chikilin's Avatar
chikilin
1st Gear
OK, i think this is Very important tread, I been messing with the fuel screw trying to get between 400 to 700 in my 1994 Idi turbo (stock), i got it in that range but my cold start is no good and is not having good boost or power , i Saw raising 900s when i was in a flat road, speeding from stops, ho!! feels good that heavy truck move fast, i have it 2 flats or 1/4 turn before max at that time, i have at this moment 6 flats or 3/4 before max and i can see is not ideal to my cold start, now i saw this tread and i am glad i can turn it more, i saw on Youtube someone saying the right temperature is in between 400f to 600f, now i know he may have it somewhere else but not on the exhaust headers, yes i have that egt sensor in between the 8 cylinder and the junction to the cross pipe, I am thinking getting it at 3 flats before max. please excuse my broken English
SouthBoundandDown
Nov 25, 2014 05:50 PM
NiftytheF150
Nov 22, 2014 12:50 PM
Splatts
Nov 26, 2011 07:04 PM
stledger
6.4L Power Stroke Diesel
Sep 23, 2008 04:06 PM
MaxRaceSoftware
Jun 28, 2002 12:30 PM
