Transmission delay on downshift.
Old Feb 19, 2009 | 10:57 PM
hella 4.0's Avatar
hella 4.0
Question Transmission delay on downshift.
Hello! I have a 2007 Ranger 4x4 w/ the 4.0L and an Automatic (5R55E) 36,500 miles. I am having an issue with downshifting. I am not certain at what speed it takes place but I'd say between 30-45. Okay, scenario.... I'm driving in town at about 35 mph and i need to get around a slow driver. So naturally, I push the accelerator to the floor. And this is where it slowly builds RPM's, for about 3-5 secs, to probably about 4000 or so (sorry I'm not sure, I'm usually mad that is won't shift so I'm not paying attention to specifics.) and then VIOLENTLY shifts to second and quickly into third and so on. Just wondering why it has to build the RPM's before the downshift? It doesn't do this everytime, but more often than not. Any ideas? thanks for reading!!
hella 4.0
Old Feb 20, 2009 | 12:34 AM
Bear River's Avatar
Bear River
Former ******
Time for maintenance. New fluid and filters will do wonders, and it should be done every 30,000 miles or three years at least.
Old Feb 20, 2009 | 10:05 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
I like Bear Rivers idea.
Kinda sounds like you may have some internal tranny gum, varnish, or sludge deposits hanging things up.
Maybe consider a dose of Seafoam Trans Tune & see if the shifting improves or the hanging up down shift stops, then do a tranny pan drop, filter change & continue on with a full fluid pump out.
Here is how I did a tranny pan drop, filter change & full fluid pump out on both of my rides & was rewarded with improved shifting .
https://www.ford-trucks.com/forums/6...-pump-out.html
Let us know how it goes.
Old Feb 20, 2009 | 11:58 AM
freirefishing's Avatar
freirefishing
my 06 has had violent and sloppy shifting since day 1. i now have 64k on it. 4.0 4x4 automatic 4:10 gearing
Old Feb 20, 2009 | 06:35 PM
hella 4.0's Avatar
hella 4.0
Okay! Thank you guys for your knowledge! I will try to get that done asap.
hella 4.0
LARIAT 85
17
Dec 26, 2020 09:51 PM
LARIAT 85
Sep 7, 2016 01:22 PM
sbeamer
Aug 11, 2016 09:31 PM
meborder
Jun 28, 2016 02:31 PM
BlowNdoh
Jul 30, 2014 08:22 PM
