Aftermarket Products
Sponsored by: Worksport
Throttle body spacers
Old Sep 21, 2001 | 12:48 AM
77_f250_460's Avatar
77_f250_460
Old Nov 21, 2001 | 09:33 AM
stevieray's Avatar
stevieray
I recently have heard of a throttle body spacer for EFI motors that supposedly increase power and torque. I have a 93 5.0 and would like to have more of both. Wouldn't we all. If any one has heard of these items I would appreciate hearing from you. SR
Old Nov 21, 2001 | 02:36 PM
toughf1's Avatar
toughf1
I have heard a lot about spacers as well, my friend has one in his dakota and he loves it. I know that Jeg's and Summit, and all of those other catalogs have some in there. They are about one hundred bucks. Does anyone know if one is better than another, or if they are all about the same?
-Shawn-
1988 F-150 4x4 5.0
Old Nov 29, 2001 | 11:05 PM
fordextreme's Avatar
fordextreme
I put a throttle body spacer on my 99 f-250 SD with the 5.4 ltr triton. I have a whistling soudn much liek a turbo. is thsi normal? I checked for leaks and none come up
S
Old Dec 11, 2001 | 09:25 PM
Justin89's Avatar
Justin89
wouldnt a spacer only be good to a Throttle Body Injected motor(or carb) the way i undestand it is that they alow the fuel and air to mix better, making more power, but if u put one on an EFI motor all the throttle body does is let air into the motor, so if you put a spacer in it that is just a longer way for the air to go. someone correct me if i am worng. Just my 2cents
Old Dec 24, 2001 | 08:52 PM
AZ4x4f150's Avatar
AZ4x4f150
if you have TBI the spacer will work good but if you have EFI or multi port fuel injection it won't what you will need is a performance mass airflow sensor whivh summit and jegs sell i installed a new mass airflow sensor on my wifes Grand prix and let me tell you it made alot of difference in the performance
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
