9 inch
Old Feb 19, 2009 | 08:11 PM
pro70golfer14's Avatar
pro70golfer14
ya a 9 inch wouldbe in my truck if the speed sensor deal wasnt a problem. but instead i had to just by more gears for the lousy 8.8 and keep running it. if i wanted to go to like a 10.25 out of a bigger truck, do they have speed sensors on the rear end?
Old Feb 19, 2009 | 08:16 PM
jk89cat's Avatar
jk89cat
Originally Posted by humpstowing
I have a 9inch in my 90 mod F150 & there was no mods to put it in if you go to the 250 diff I think you would have to change to 8 stud rims I think?
ummm no mods? diff mounted speed sensor is quite a big one
Old Feb 19, 2009 | 08:21 PM
BigBlueOx's Avatar
BigBlueOx
yes the late model F-250s have the speed sensor in the rear. I have a '96 F-250 donor truck that I'll sell you the rear end.
1966Tbird's Avatar
1966Tbird
not on a 90 the speed sensor is on the tailshaft
Old Feb 20, 2009 | 08:58 AM
humpstowing's Avatar
humpstowing
My speedo pick comes out of the transfer case it is cable but also has wires coming out of the pick up as well at this stage I don't know what the wires do as the cable go's up to the dash
Old Feb 20, 2009 | 10:58 AM
1966Tbird's Avatar
1966Tbird
something you could try is put a yoke in the tranny pull the driveshaft and put it in drive, if the speedo works then that means you can ditch the 8.8 for a 9in
Old Feb 20, 2009 | 04:51 PM
EPNCSU2006's Avatar
EPNCSU2006
The wires coming from the tailshaft where the speedo cable mounts, link the VSS (in-line with cable at transmission/transfercase) to the engine computer and cruise control. The speed sensor in the rear end was only used for RABS on 87-91 trucks.
Old Feb 21, 2009 | 05:23 PM
humpstowing
Ok being that my F series was one of the early EFI 351's(no longer in car) in Australia & has never had cruise control is there any way to use the wire's to run the cruise or do they only register motion not the actual speed.
Old Feb 21, 2009 | 07:25 PM
351slug's Avatar
351slug
About Brea Auto Electric: Products: Speed Sensor
Old Feb 21, 2009 | 07:33 PM
BigBlueOx's Avatar
BigBlueOx
like I said someone had to make a solution to the problem at hand. Thanks 351slug
Old Feb 22, 2009 | 09:02 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm not really sure to be honest. The VSS should give an actual speed as far as I know.
