coolant overflowing from overflow
Old Feb 18, 2009 | 08:04 PM
jermyjudge's Avatar
jermyjudge
my 1998 ranger lately has been pushing coolant from the radiator in to the overflow and not pulling it back into the radiator. Every couple of days I have to fill the radiator or it will overheat. I replaced the thermostat and cap no luck. The truck does't overheat until the coolant in the radiator gets low. Any help would be great.
Old Feb 18, 2009 | 11:33 PM
Bear River's Avatar
Bear River
Former ******
This usually means there is a leak somewhere. The fluid expands into the overflow, but as it cools, air gets pulled in through a leak. Over time more and more coolant is lost and not recovered. Find the leak and fix the leak, then the problem you are experiencing should go away. Make sure the leak is not in the overflow tube itself, we had a tube that wasn't sealed on the neck of the radiator, so the water would flow down, but not back up.
Old Feb 19, 2009 | 12:20 AM
michigan66's Avatar
michigan66
You may still have an air bubble in the cooling system thats causing the overflow and over heating. Check for that as well as a possible leak.
Old Feb 19, 2009 | 02:19 PM
Peter94's Avatar
Peter94
Also watch out for a head gasket leak. Alot of times this will cause high pressures in your cooling system, pushing it past your radiator cap, and into your overflow.
joshofalltrades
Dec 7, 2014 10:04 AM
Deuce40s
Nov 23, 2014 04:22 PM
Wild Weasel
Jul 12, 2014 01:34 PM
96_F250_Deezal
Jan 23, 2014 09:19 PM
59INA40
15
Mar 4, 2009 11:41 AM
