spartan archived tunes who likes what?
well sounds like you guys have serious issues with your lack of confidence in the 6.0 however I do not. I do not really plan on running the ultra comp i was just looking for some info if anyone had i'm looking for some real stories of heads lifting and so fourth as you claim they will, i was not looking for smarta## answers or sarcasm, the main reason i asked was a previous guy posted that he uses ultra comp as a DD and he didnt specify if he has studs it isn't listed in his sig.... anyways i'm not really worried about what i do to this truck i will just fix it its not like i'm an idiot who knows nothing or doesn't have the cash to play expensively it jus seems everyone is so scared as i likewise have been but i've been running the HR (when i'm not towing) and \have no problems and I drive it responsibly but I do give it hell havent had any problems egt, boost, nothing over any dangerous levels and no signs of anythin wrong yet, i like experiments i'm also settin up a turbo experiment if i can get all the funds to do it how i want, to test the aftermarket intake effects on the turbo like K&N vs stock I want to put a turbo on a blower and put the filter on the other end and run some pretty dirty stuff thru it and set up the stocky the same with the little woosy tube on it, just as set up on the truck, also to see which one flows better.
sorry for the hostility i just get agrivated i don't claim to know it all and i always listen to waht people say or think
My fault, yes I do have missing things in my writing. I go to school and have to use proper grammer in class, and I have a problem with getting excited and word vomet so I do not like to follow the grammer rules. I also own two businesses and i've had a hec of a day and I have been snapping on just about everyone. anyway sorry
I run the ASE as my daily driver, I have no studs as of yet.
As for the power, I have "almost" to much with ASE (uncontrolled wheel spin)...To much power is just enough...LOL
At this point I think my heads will/may be alright as long as I watch
my EGT's and boost..
I have hammered it a few (several ) times, never seen hot Temps or high
boosts..
My thoughts are, the Transmission will/may fail first....
I was tempted trying Ulta Comp or Race, I do not trust the stock Transmission.
My Transmission already failed at 32,000 with a completely stock truck.
I will wait on installing studs and a sun coast Transmission before going above ASE..
boosts..
I got ya like I said just a little on edge today I've been gettin pi#### all day. Yes I would like to know also. I'm tempted to run it but at the same time I'm reluctant that's why first off I wonder if anyone has rrun it without studs, as brickie said that will probably happen. However I do like to experiment and I may just do it and document how long, it any amount of time, it takes to do some damage. Also brickie, have you known someone to do this or is it just the sheer math and knowledge that leads you to this conclusion, or mayb just knowledge form Matt or a diesel tech?
#28
boosts..
boosts..
#29
I did run the Ultra Comp for a DD, but it probably wasn't me who mentioned it, because I have studs for a while now, and it's in my sig. You are not going to lift your heads right away when you start up your truck with it, and sure can drive in traffic with a light foot on the pedal, and you probably gonna be just fine. But if, then what is the UC doing in the truck right? They were written to be a racing tune. I never understand whoever runs a hot tune with a light foot, because there is no supporting mods in the truck. Then just find a tune, what was made for a truck like that, and enjoy it. Aha, curiosity comes in the picture. Everyone want to know how badazz the one step hotter program is, and just take it easy on the pedal. Than something goes....That's exactly how the "bad" stories are starting about the 6.0 and the programmers. It is obvious that the 6.0 has it's weak points, but which vehicle doesn't?
Anyways, back to the topic, Brickie is right, if you run through the gears on WOT, there is a big chance that you will blow the gaskets on a non-studded truck. I was having fun, racing, testing with the UltraComp program, watching the gauges and I have to say, that there is a really big chance to blow the gaskets. The highest boost I've seen with it was 38psi, and the EGT was around 1500. I doubt that the OEM bolts will handle that boost, and sure as h*ll your EGR cooler wont like the temp either.
Play as much as you like, do your experiments, and if you have the money set aside for the studs, go for it. Load up the UC, and give it to it. The only thing what I don't understand, why not install the studs, then run the UC. In that case you would make sure that your truck is ready. Why play with fire, if you have a chance to do it on a right way? Don't be sure, that you blow the gaskets, and gaskets only, with hot tunes! How about something else goes wrong?
#30
