Real or not
Old Feb 18, 2009 | 09:10 AM
wantatruck's Avatar
wantatruck
Real or not
I,m looking to buy a F250 with the 6.0 diesel that I would like to pull 21" travel trailer with. After doing a little research I've read that the 03 and 04 might have some injector and head issues. Are these real or isolated problems.
Old Feb 18, 2009 | 09:29 AM
juneau76's Avatar
juneau76
They are hit or miss. Some engines were good and others were not so good. I have an '03 that had issues early in life, but they haven't been as bad later in life. There are also some later model 6.0s that have issues, as well. Our ambulance is and '06 and it has issues. Although, maintenance and how you treat it is a major factor. Make sure you get an Oasis before you buy something. Good luck.
By the way, welcome to FTE!
Old Feb 18, 2009 | 10:05 AM
wantatruck's Avatar
wantatruck
What is an Oasis?
Old Feb 18, 2009 | 10:21 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Its the repair history of a vehicle during it's warranty period. In your case, it's first 5 years or 100,000 miles.
It'll tell you if it's a truck with a troubled past or if you're looking at a truck worth buying.
Old Feb 18, 2009 | 06:45 PM
liv's Avatar
liv
Your not going to fit much in a 21" trailer... sorry I had too.
Listen to the genius's and get a oasis report. Post it here if you don't understand it. <3 my early 03, but like stated before it's hit or miss.
Old Feb 18, 2009 | 07:24 PM
BAF350's Avatar
BAF350
Go 6.0
Like everyone else has said get an OASIS report and do a little homework. My '03 has been an awesome machine since day one, brother-in-law not so lucky. But rest assured the 6.0l will beat the pants off a 7.3 anyday! Good luck!
Old Feb 18, 2009 | 10:52 PM
rollerstud98's Avatar
rollerstud98
Issues can be had throughout the 6.0 run, techs have smartened up and instead of just fixing the problem at hand and calling it fixed, have started to locate and fix the cause of the problem, lots of multiple head gasket problems were caused by reuse of warped heads, and the turbos causing the problems but not being replaced or cleaned. Although I do believe they no longer just clean them if under warranty
Old Feb 19, 2009 | 05:44 AM
EOD Guy's Avatar
EOD Guy
I purchased a used 04, very happy with it
senix
All Things Towing
72
Nov 3, 2019 08:02 AM
ostrx250
Jan 25, 2015 11:02 AM
traveler110
Feb 14, 2014 05:27 PM
rmcgaffin
Mar 17, 2008 11:07 AM
Mil1ion
Jan 4, 2002 02:16 PM
