Modular V10 (6.8l)
synthetic/regular oil question
Old Feb 18, 2009 | 09:02 AM
switzj's Avatar
switzj
I have a 1999 F-250 V10 gas. I recently put 3 quarts of Mobile synthetic and 3 quarts regular Mobile. Is this okay for my engine? I have read this is cheap way to make oil synthetic blend. Any thoughts?
Old Feb 18, 2009 | 09:49 AM
dkf's Avatar
dkf
Buy some Motorcraft 5w-20 synthetic blend oil. It will be cheaper than buying 3q of dino and 3q of synthetic. You won't have to wonder if they mix well together, which they should no problem. MC blend oil is cheaper than dino often times.
Old Feb 18, 2009 | 09:51 AM
switzj's Avatar
switzj
Thanks for the update. Is Motorcraft 5w-20 synthetic blend good oil though?
Old Feb 18, 2009 | 11:11 AM
dkf's Avatar
dkf
Yes, its great oil. I run the MC in the warmer months and a full synthetic during the winter.
Old Feb 18, 2009 | 06:14 PM
429law's Avatar
429law
mc 5w20 is great oil, get it at wal mart. I ran mobil syn for a long time and moved to 5w30 val syn which protects 4x better then m1 well that is what they say. I know one thing for sure you can't go wrong with what ford says to use.
Old Feb 19, 2009 | 09:56 PM
oldirtytruck's Avatar
oldirtytruck
I agree... don't buy two kinds and mix them. Just buy the blended stuff and you will be okay. I run 5w-20 M1 full syn in my 03' and it does fine. Just have to add a quart every 3k.
Old Feb 20, 2009 | 02:10 AM
shanksyamaha's Avatar
shanksyamaha
is there any reason you cant use full synthetic? Im gettin ready to change mine and I was thinking of going with a full synthetic oil..
Old Feb 20, 2009 | 09:39 AM
switzj's Avatar
switzj
I would run full synthetic but it cost too much money for the efforts and I like to change my oil every 4-5000 miles. I have heard too many complaints with not changing full synthetic for 7-10000 miles.
Old Feb 20, 2009 | 01:33 PM
mwsF250's Avatar
mwsF250
Your priorities and desires closely match mine! I normally run full synthetics in my rigs, but with towing, I like changing pretty frequently. Mixing SHOULD be OK, but there is a tiny risk the combo you choose results in a less than optimal additive package.
I decided the MC 5W20 semi-syn blend was the best solution for me.
Old Feb 20, 2009 | 02:39 PM
oldirtytruck
I run full syn in mine and change it a 5k-6k miles with no problems.
Old Feb 20, 2009 | 09:29 PM
MadMedic20's Avatar
MadMedic20
I run Valvaline 5w-30 MaxLife with Lucas oil stabalizer in the X with 120,000 miles on it. I run MC 5w-20 in the Mustang with Synthetic Lucas oil stabilizer.
Old Feb 21, 2009 | 02:41 AM
shanksyamaha
I have used full synthetic for years now. I had a geo metro with a 3cyl motor running full syn and changed every 4-5k and that car had over 200k on it when the frame broke, motor never used a drop of oil. I plan to run only full synthetic in my v10 also, I know it takes like 6 quarts but you can still do a complete oil change for around $35 and thats only 7/10 of a penny per mile if you change it at 5000 miles. sounds like a good deal to me.....
Old Feb 21, 2009 | 09:49 AM
Zedrive's Avatar
Zedrive
Leave the mixing to the labs. We're talking chemistry here.
Run full Syn its just all around better or run Syn blend if costs are an issue.
Regular Dino oil with regular filter changes has worked for decades. be religious on the interval.
Blending it yourself is a crap shoot IMO.
Damn, thats like mixing Canadian club whiskey into Crown Royal.
Old Feb 21, 2009 | 10:56 AM
Gage2502's Avatar
Gage2502
Im useing full synthetic on my 2005 SD and I still change it every 3 months/3k.
In the summer I was thinking about useing motorcraft synblend and of course im useing the great motorcraft filter with any oil I use.
~Gage~
