backup light switch
Old Feb 18, 2009 | 08:09 AM
rbcyouthdude's Avatar
rbcyouthdude
backup light switch
2005 explorer, good fuse and the backups don't work. I ordered a part from Ford and got this part
http://autoparts.cardomain.com/auto-...n-speed-sensor
but I think I need this part
PartsTrain.com - Hard to Find Auto Parts and Truck Parts -
Which one is it and where is the second one located, on what side of the tranny and is it way up high?
thanks
Michael
Old Feb 18, 2009 | 11:47 AM
87 XLT's Avatar
87 XLT
The closest factory wiring diagrams that i have are for my 97 Ex, yours is probably wired the same.
On my 97 the backup lights are wired to the "digital transmission range sensor" which plugs into the drivers side of the transmission & -at least on the 97- has an 11 wire connector.
The trans speed sensor in your 1st link is not what you need & I could'nt pull up your 2nd link .
Old Feb 18, 2009 | 12:49 PM
87 XLT's Avatar
87 XLT
BTW, if you enter the info for your 05 at autozone.com you should be able to pull up the backup lights circuit wiring diagram.
Old Feb 18, 2009 | 01:46 PM
rbcyouthdude
on this page at autozone,
AutoZone.com | Vehicle Selection - Year I look at component view #5 and I still don't see the backup switch.
Michael
Old Feb 18, 2009 | 02:12 PM
87 XLT's Avatar
87 XLT
Well, go figure, I cant pull up your autzone link either.
As they say a picture is worth a thousand words & if you stop by a Ford dealer parts department they can pull up a picture showing the location of the DTRS.
Since the fuse isnt blown it looks like a busted wire or bad DTRS/digital trans range sensor.
On the 97 the DTRS for the 4R70 & 5r55 trannsmissions is at the drivers side bottom of the trans. Dont know if yours is the same.
Have you looked at your trans?
Old Feb 18, 2009 | 03:04 PM
rbcyouthdude
http://www.explorerforum.com/forums/...=181811&page=4
I have looked, is it visible on these photos?
Old Feb 18, 2009 | 03:23 PM
87 XLT's Avatar
87 XLT
Yeah, the sensor on the drivers side bottom of the first picture matches the picture that I have in the 97 factory wiring diagrams
Old Feb 18, 2009 | 03:46 PM
rbcyouthdude
The big Black thing?
Thanks so far for your help.
Old Feb 18, 2009 | 04:46 PM
87 XLT's Avatar
87 XLT
Yep, if your 05 is setup the same way it will have "that big black thing".
Good luck with it
ryanlee450er
Dec 1, 2011 10:25 PM
jsalas818
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 2, 2011 07:25 PM
i eat hybrids
Apr 4, 2011 11:45 PM
coop923
Aug 4, 2008 10:24 AM
antunez13
Apr 7, 2008 11:14 PM
