coolant problem
Old Feb 18, 2009 | 12:20 AM
fastball's Avatar
fastball
coolant problem
Looked under my hood today and the degas (Coolant) bottle is squirting coolant from the lid all over the place. Does anyone know what is going on here? Also driving down the highway or a quick takeoff, when I give it some throttle the turbo/air intake has a high pitched sucking sound like a throttle body spacer on a gaser. What the hell. Also some days going down the highway at 115/120 kms, the turbo boost guage is almost at 1, other days it is at 1.5/2. Does the cold temp have something to do with it?
I'm driving an 07 6.0 F-350 HD. Anyone out there having the same problems?
Thanks,
Mike
Old Feb 18, 2009 | 12:25 AM
jmaskew's Avatar
jmaskew
Thanks,
Mike
The "puking" of coolant out of the degauss bottle cap could be pressure build up from stretched head bolts or the egr cooler is getting a restricted flow of coolant from the oil cooler (plugged with casting sand) and the coolant is boiling inside the egr cooler causing pressure.
Old Feb 18, 2009 | 07:19 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Is your coolant level at the min line on the resevoir? If not I'd remove coolant till it's sitting at the min mark. If it keeps blowing coolant, the next thing I'd try is replacing the cap. They have been known to go bad. If that doesn't work, then I'd start thinking about EGR cooler issues or HG issues.
Tanbeard
Jul 8, 2013 12:43 AM
cay5628
Jun 14, 2013 11:03 PM
frenchy750
Jan 20, 2011 04:13 PM
Hollywood2005
6.4L Power Stroke Diesel
31
Jan 5, 2009 10:03 AM
ASH
Aug 6, 2003 07:41 AM
