Bronco II Ford Bronco II
m5od
Old Feb 16, 2009 | 11:47 PM
hockeyfan's Avatar
hockeyfan
m5od
is there a difference between the r1 and r2. would the r2 bolt up fine on a 4.0 from an explorer or ranger?
Old Feb 17, 2009 | 02:10 AM
kernel-panic's Avatar
kernel-panic
Depends on the bellhousing bolt pattern. M5ODs have also been used behind other engines besides the 2.9/4.0: Essex V6s, Vulcan V6s, etc. - to include the 3.8s in the F150s, IIRC. As long as the transmission has the right bolt pattern on the bellhousing, it should work - IIRC, the M5ODs did not have a removable bellhousing.
Not sure which one is 'better' (M5OD, M5OD-R1, R2, etc.) - you may want to look in the tech section here or on RangerStation.
Magnus E
Dec 1, 2016 08:27 AM
f100today
Oct 25, 2016 05:03 AM
the droom
Sep 21, 2015 07:40 PM
Motorhead351
WTB - Parts & other
Aug 22, 2015 07:02 AM
kelsbell
General Automotive Discussion
Aug 21, 2015 11:49 PM
