4 driving lights
Old Feb 16, 2009 | 06:03 PM
digger190's Avatar
digger190
4 driving lights
how can i run 4 100watt lights off of one upfitter switch.these lights will be on the back of my truck and wont be on for any length of time as they will be used for only short amounts of time. thanks in advance
Old Feb 16, 2009 | 06:48 PM
Franklin2's Avatar
Franklin2
400watts divided by 12 volts = 33.33 amps. I believe the largest circuit on the upfitter is 30 amps. You will have to use the two 30 amp upfitter switches, or use one and add tap into a power source with a fuse, add another relay, and use the one upfitter to trigger the upfitter relay and the added relay.
Old Feb 16, 2009 | 07:06 PM
digger190's Avatar
digger190
dont want to seem like a lamen but could you or some one kindly draw that out for me,please
Old Feb 16, 2009 | 09:24 PM
Franklin2's Avatar
Franklin2
Here's a link to the upfitter info.
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old Feb 17, 2009 | 06:31 AM
digger190's Avatar
digger190
thank you Franklin2,but what wire goes to the switch
Old Feb 17, 2009 | 08:33 AM
digger190's Avatar
digger190
ok,bear with me,im not an electrician. so i can add an inline fuse-then a 30 amp relay-then run the wire under the dash for the upfitter switch for one set of lights but splice into the same wire for triggering the relay for the other set of lights.
Old Feb 17, 2009 | 05:06 PM
Franklin2's Avatar
Franklin2
The wire going into the fuse box is the one pre-wired to the relay and switch that comes with the upfitter option. If you look in the link above, it tells you the location, the color, and which switch goes to which wire.
So just hook one upfitter circuit to two lights in the rear. That will get two of them working. Then add the extra relay and the other set of lights, and use the wire you just used for the first set of lights to trigger the added relay.
Drwoods72
1997 - 2003 F150
Feb 14, 2017 05:25 PM
76 F150 4x4 Custom
Aug 29, 2016 09:35 AM
Icefan71
Nov 17, 2008 07:20 AM
stacyj
Jun 15, 2005 06:21 PM
secondstar
Electrical Systems/Wiring
Aug 29, 2001 11:57 AM
