1988 300 inline 6 swap
Old Feb 16, 2009 | 03:46 PM
bcallahan's Avatar
bcallahan
I have a 1988 f-150 w/ a 300 inline 6 efi I was givin a 1970 300 inline 6 with 7000 miles on it will the 1970 300 bolt in or is it a waste of my time to try??
Old Feb 16, 2009 | 06:03 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
It should bolt right in. You plan on swapping the fuel injection over don't you? I'm not a 300 expert, but you should be able to swap over the EFI stuff to the 1970 block.
Old Feb 16, 2009 | 06:41 PM
rostena's Avatar
rostena
Very simple swap. Everything should line up nicely. If you plan on sticking EFI well then someone else will have to help you but if your keeping the carb, just get yourself a fuel pressure regulator that brings the PSI down to about 7. Otherwise you can do what I did and rip all the electrtic fuel pumps and such out and use the mechanical pump.
Is your tranny manual or automatic?
Old Feb 16, 2009 | 07:25 PM
bcallahan's Avatar
bcallahan
It is a 4 speed manual Trans i would like to keep the efi if it will work
Old Feb 16, 2009 | 08:47 PM
1994 F250: 351, C6
The EFI stuff should work. You will need the intake manifold of your EFI truck and all the stuff that comes with it. I'm not sure about the cylinder head though. If you are luck you will be able to bolt the EFI manifold to the 1970 head. If not, take your EFI head apart and have it tanked and machined, then install it on the 1970 motor. Good luck!
olfordsnstone
Mar 16, 2012 12:35 AM
blueeyedfordguy
Sep 24, 2009 11:15 AM
Supercab
Jan 3, 2009 12:06 AM
bhopper
Apr 10, 2004 05:50 PM
