1966 - 1977 Early Broncos
problems at 800 rpm
Old Feb 16, 2009 | 10:31 AM
68 351 bronc's Avatar
68 351 bronc
problems at 800 rpm
Ok, so this is the first winter I have used the EB as a daily driver.
I figured out why my 351W gets hot while crawling at slow speeds.
If I let the motor idle, which is set around 750-800 rpm, the water pump doesn't circulate any water through the radiator or heater core.
This is how I came to this conclusion.
1) the temp climes to 210+ degrees but the heater blows cold air and
2)the radiator tank is cold
Rev it up to around 1100rpm and the heater warms up, engine cools down.
Now for my question, I have a harmonic balancer that is drilled for 3 or 4 bolt crank pulleys. I am running the stock 3 bolt, 2 grove pulley. I would like to speed up my alt and water pump to work better at low rpm.
Can I get a bigger crank pulley??? where??
Old Feb 16, 2009 | 11:46 AM
RCrawler's Avatar
RCrawler
I haven't ran across anything much larger than stock. I have seen some smaller water pump pulleys, but none with the correct offset. You may have to make something up.
How is the condition of your water pump and thermostat? What temp t-stat are you running?
Jason
Old Feb 16, 2009 | 12:30 PM
68 351 bronc
All are in great condition. I changed out the POS rebuilt pump for a new Miloden from Summit. Impeller clearance is machined very close tolerance so I don't think there is a better pump out there.
Running a 190 thermostat.
The alt doesn't put out well at an idle, (I am running a volt meter not amp meter)
Old Feb 27, 2009 | 09:53 PM
big bad 79 bronco's Avatar
big bad 79 bronco
i would recomend a high flow pump i had same problem on my 69 that took care of it buy the castiron pump its alot cheaper works great
Old Mar 2, 2009 | 09:28 PM
Boba Fett's Avatar
Boba Fett
Also the condition of the heater box itself could be the culprit on why you feel cold air. The HVAC system in these early broncs is only marginally better that none at all!
The heater systems don't throw all that much heat from my experience. Somethimes the baffles in the box are bad or not connected properly to the dash mounted actuators which only add to your woes.
I run my Bronc without carpet or heat shield... get better heat from the engine compartment and exhaust than I ever do from the heater!
