Rear end trouble???
Old Feb 16, 2009 | 07:05 AM
jamie7375's Avatar
jamie7375
Rear end trouble???
Hello all. Here is my problem. 2004 f250 6.0..When i put the truck in drive and go to take off it feels like the rear wheels dont catch right away. About a second later the trucks catchs slightlyand goes fine. Does not matter how I start off ut its not as bad if I am rolling and then accelerate. Any ideas would be greatly appreciated.
Old Feb 16, 2009 | 08:51 AM
Bustaduck's Avatar
Bustaduck
not a clue but mine does the same thang and has been doing it for long time. I had the rear end rebuilt. To be honest I thank it is the transmision. Mine is 03 6.0 4x4 140,000 k maybe sombody out there knows the problem sorry
Old Feb 16, 2009 | 09:06 AM
jamie7375's Avatar
jamie7375
Mines an 04 with 135k...I change the tranny regularly and never found any metal..Wondeing if its the slip yoke that needs grease. i read a thread on hear about that...
Old Feb 16, 2009 | 09:40 AM
Wyatt66f100's Avatar
Wyatt66f100
sounds normal. takes a while to engage.
Old Feb 17, 2009 | 09:51 AM
rocknut's Avatar
rocknut
sure it's not a solenoid in the tranny? There is play in the rear end but not a full second worth of play. The solenoids in the tranny have been know to go bad. I had one replaced in mine. Then my tranny went bad shortly after that.
Old Feb 17, 2009 | 10:00 AM
firesoutmatt's Avatar
firesoutmatt
First quess would be u-joint or slip-joint on drive shaft worn.
