My wifes 1998 expidition back power vent windows dont work (used too)
looked thru owners manual did not see any info or fuse location anbody?????
Point me in the right direction dont know where to start
fuse, relay?????????
I think it shares relay and possibly fuse with moon roof, if so equipped. If you have the moon roof, does it work? Otherwise I will check into it later today.
On checking the wiring manual it shows that the power to these windows as well as the moon roof are controlled by a 30 amp maxi fuse. This fuse is in position 29 in the power distribution box under the hood.
fuse is good will pull panel to check relay man its cold out there
thanks for info so far good time to replace blown back speakers
wonder if my old super duty door speakers will fit?? not to get off main subject ill pull back panel tommorro
