Adding a digital water temp gauge?
Old Feb 15, 2009 | 11:59 AM
460's Avatar
460
Hey all, I'm wanting to add an electrical water temperature gauge to my '79 and still retain the factory dash gauge.
What type of sending unit is required for the aftermarket gauges?
Can I simply splice into the wire for my stock gauge? With both still read accurately?
Here is the gauge I want to use... Cyberdyne A020E060N - Cyberdyne Digital Red Heat Gauges - summitracing.com
Old Feb 15, 2009 | 12:08 PM
Bgasrickshaw's Avatar
Bgasrickshaw
If you look on the right hand side of that summit page it has a list of suggested parts, one of which is the correct sending unit for that guage ($15 or so) i'm sure it comes with installation instructions as well
Old Feb 15, 2009 | 12:20 PM
460's Avatar
460
I'll use that if I have to, but I'm running out of locations for my sending units...
Is there somewhere in the cylinder head for the 1/8" sending unit?
Currently I have the following sending units:
1. Coolant temp sender for the gauge
2. Coolant temp sender for the computer (fuel injection)
3. Low speed fan switch
4. High speed fan switch
Old Feb 15, 2009 | 12:47 PM
kingford72's Avatar
kingford72
I had to take a peice of tubing about 4" lg and put two bungs and a nut on and splice it into my radiator hose for some extra spots for senders the nut is for a wire to run back to the block for ground for the sender. There is no spots on the head. Can you drill and tap one, I have not looked in to it. The sending units could be the same or they could be diff. you have to get the specs. from the manufacturer.
FORDF250HDXLT
45
Mar 23, 2013 02:40 PM
Bullitt390
1983 - 2012 Ranger & B-Series
Jan 24, 2012 01:49 PM
George84
Nov 20, 2010 09:14 PM
1-bigmac
2004 - 2008 F150
Jan 30, 2008 08:57 AM
AegisSailor
Aftermarket Products
Aug 20, 2003 04:01 PM
