MP3 jack
Old 02-14-2009, 04:42 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
MP3 jack
Ok..i have a lariat with the center console shifter...so up above theres the black panel where the lighter and rear back up sensor switch is mounted....well i want to put in a mp3 jack there cause the one up on top annoys me that a cord is always hanging down the dash...anyone know where i can get a jack that will snap into a hole i drill in that???
Old 02-14-2009, 10:25 PM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
Are you simply looking for a 3.5mm (or whatever the dimension is) port basically? Does your truck have the jack from the factory, or is this something you are adding?
Old 02-15-2009, 07:29 AM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
I'm listening...I hate where they put the factory jack. Even though I live in a safe area, I'll be damned if I'm going to leave an iPod touch sitting up there.
Old 02-15-2009, 07:37 AM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
"3.5mm stereo (f-f) panel mt. 3/8" hole"
This should accomplish exactly what you are looking to do. You will simply need to undo the factory jack, and tuck it back into the dash, then run a M-M stereo cord from it, to one end of this panel mount.
Old 02-15-2009, 09:01 AM
ChargersFanInCO
Need pics of where you're mounting it to. I want to move mine.
Old 02-16-2009, 12:59 PM
Ryan50hrl's Avatar
Ryan50hrl
Hum...thats what i need....but i want something cleaner looking....i'll get back to you all....
Old 02-16-2009, 01:36 PM
Ryan50hrl's Avatar
Ryan50hrl
Custom: MP3 Car Audio Cable - 3.5mm Female Panel Mount to Stereo RCA Audio | ShowMeCables
K...this is getting closer....actually it would work...but i want something a little cleaner looking without the nut and threads on it...anyone know of anything?
Old 02-16-2009, 01:54 PM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
The nut and thread about be on the inside of your dash (or glovebox, or wherever you are mounting it). This is a panel mount (may or may not be a D hole), so all you would see on the face is the round step shown in the front of the product. You could drill damn near anywhere (Ive seen it done inside the dashboard compartment), for a stealth install that you never see.
Old 02-16-2009, 02:41 PM
Ryan50hrl's Avatar
Ryan50hrl
Does anyone know if you can buy parts of a wiring harness seperate....for example...the wiring harness that goes up to the jack stock...is a funky 4 wire plug....i want to keep the stock input as well as the second one i'm installing...can i get the wiring that plugs into the jack from ford?
Old 02-16-2009, 03:50 PM
ChargersFanInCO
Splice the wires and make them longer.
Old 02-17-2009, 12:00 PM
BorderFord4X4's Avatar
BorderFord4X4
BorderFord4X4 is offline
Radio shack has one that will look stock, if my camera was working I would post some pics for you.But it has a black cover and I put it exactly where you want to and it fits perfectly.
Old 02-17-2009, 12:08 PM
Ryan50hrl's Avatar
Ryan50hrl
Excellent.....i'll have to head over there later today.
thanks...
Old 02-17-2009, 05:09 PM
Ryan50hrl's Avatar
Ryan50hrl
Ok...i went into my radio shack here....and they had NOTHING that had a black cover or anything similar......is there a part number or anything you saw on it?
Old 02-17-2009, 07:38 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
subscribing to hear an answer...I want to play my iPhone through the factory radio
Old 02-19-2009, 10:52 AM
Ryan50hrl's Avatar
Ryan50hrl
anyone.....I still need to find a better looking panel mount jack...
Quick Reply: MP3 jack
