1 quart to much
Old Feb 14, 2009 | 03:52 PM
meanv10's Avatar
meanv10
1 quart to much
just did a shift kit and it looks like we put about a quart to much in, could this be a big deal or do any damage to the tranny, if you look at the dip stick its on the second "d" of don't add.
Old Feb 14, 2009 | 04:00 PM
75F350's Avatar
75F350
As you run the truck and get it up to temp, the fluid will expand and may try to escape from the vent, or the dipstick tube. Usually makes quite a mess when this happens.
Old Feb 14, 2009 | 04:18 PM
meanv10's Avatar
meanv10
it read that after the test drive so it was at running temp. I just dont want to wreck anything.
Old Feb 16, 2009 | 05:11 PM
icrman's Avatar
icrman
It should be fine. I have noticed that the sticks are sometimes too low, and a bit more won't hurt. Worse that can happen is like the one guy said it could kick some out, or it would aireate make some bubbles and shift weird or slip a bit. I think you would need 2 more quarts to do that though.
