CALLING all MASTER TECH's
Old Feb 14, 2009 | 10:02 AM
jsoko's Avatar
jsoko
As a Master Tech What SPARK PLUG would you put in YOUR 5.4 3V
I want your personal opinion not what FORD says
Old Feb 14, 2009 | 10:06 AM
ggwash21's Avatar
ggwash21
https://www.ford-trucks.com/forums/search.php
Old Feb 14, 2009 | 10:13 AM
jsoko's Avatar
jsoko
Originally Posted by ggwash21
NO Help I want personal opinions from those who work on & own this (ENGINE)
Old Feb 14, 2009 | 04:44 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
personally I'd just run the OEM plugs. And just check 'em every 20-30,000 miles. really recommend you wait until the 100,000 interval, but if you are gonna do it, at least be proactive about checking them often.
Motorcraft - PZT1F (SP-462)
the one piece Champions have some issues. Some people have no problems, and some have missing problems.
Old Feb 14, 2009 | 05:19 PM
70f100longbed's Avatar
70f100longbed
I would wait to change them when it's needed, not at 20k like some ppl here just because they could break, and I would put Motorcraft back in with anti-seize on the ground shield.
Old Feb 14, 2009 | 07:12 PM
Saleenguy's Avatar
Saleenguy
OEM plugs, replace about every 50,000 miles +/- 5,000 miles.
Never seize them well, and torque to 170 inch pounds.
Old Feb 14, 2009 | 10:28 PM
Ryan50hrl's Avatar
Ryan50hrl
Waiting will almost guarantee that they will break...so proactive replacement is really the best idea. I've found very few people that actually have evidence of the champion plugs missing.....i've talked to three people that said they're junk, but all three of them admited that they think champion plugs in general are junk...not these....and i for one along with a number of other people on here have them in our trucks and they're working just fine....
I'd do the champion plugs for peace of mind...
Old Feb 15, 2009 | 03:29 PM
70f100longbed
If you follow the latest TSB they won't break. I have done several sets at 90-120k and they all came out. The longer you let the carb cleaner soak the better. Most of the plug I done soaked at least 2-3 hrs and came out with all the carbon dissolved. The motorcraft carb and tune-up cleaner in the red and white can (it's not aerosol) is the ticket. Pour 2 capfuls down each plug hole, loosen the plugs 1/8 turn, and go have a few beers or something.
Old Feb 16, 2009 | 05:20 AM
svt2205's Avatar
svt2205
Is the latest TSB still 08-7-6?
Old Feb 16, 2009 | 09:36 AM
70f100longbed
Yep that's the one. The part number for the cleaner is PM-3. I think it's less than $10
krewat
Modular V10 (6.8l)
Mar 13, 2021 04:39 PM
Jmudweiser
Jul 24, 2011 08:42 PM
bigboi04
New Member Introductions
Oct 19, 2006 05:09 AM
TeamMudd
Sep 26, 2006 02:13 PM
misfitz
Jun 27, 2005 08:36 PM
