Im putting another brake light in the rear part of the roof of the shell, where can I connect the + wire to turn on it, with the brake pedal, and maybe with the flashers but no with the turn lights?
You have to run a special wire for it from the front of the truck. If you already have a third brake light in the rear of the cab, you can hook it up there. If not, you need to go directly to the brake pedal switch.
OK thank you, so is the ONLY way to do that?
and about the third brake light, where can I tap the new wire? are any specific fuse for it? or where?
You have to tap into the lightgreen wire going to the brake switch. I have heard of some sort of aftermarket lights that you can hook to the taillights, and it will ignore the turnsignal blinking, but I have never seen one or used on before.
I assumed you are hooking up a small third brakelight on the top rear of the camper correct?
Well, many, many years ago I used one of that aftermarket lights that will ingnore the turn signal blinking, it has a little black sealed box, maybe with diodes and electronics inside with several wires in each side and worked fine, but now I cant find another similar.
The third brake light on the top rear of the camper is a 30 led light, like thouse of some suburbans from ´91., so I think is not a SMALL light.
After trying to find out where to connect the light, I found in the harness under the rear bumper, a wire with a "free" connect (non used to anything) and it has power only with the brake pedal, so I connected the light there and worked fine for some time, BUT then after a few minutes, blown the fuse # 13 (15 amp) in the dash. What can I do to fix that, put a bigger fuse or to put some relay? or what, thanks for your input.
LED's don't draw much current at all. I would check the wiring to and in the camper. A led light should not have blown a 15 amp fuse.
Well, the brake light is the only one light in the camper, and its new, I just installed a few days ago. But Im going to check the wire a found and the new connections for some kind of possible shorts. Thanks again.
