99 Expedition T-case problem
Old Feb 12, 2009 | 10:08 PM
Warfarin's Avatar
Warfarin
Ok here is my problem I have a 99 Expedition with no 2hi. the settings are AWD, 4H and 4L. When I turn the switch to 4H or 4L nothing happens. I know the light has not burned out as it comes on when you start the vehicle. My other question is, is the AWD working? Any Ideas?
Thanks
Old Feb 12, 2009 | 11:32 PM
alloro's Avatar
alloro
If you don't have 4H or 4L then you likely don't have AWD either. Usually when people have this problem they end up replacing the shift motor down on the t-case.
Old Feb 13, 2009 | 02:35 PM
Warfarin's Avatar
Warfarin
I'm sure it is an expensive fix but is it an easy one?
Old Feb 13, 2009 | 03:13 PM
maldbwmjr's Avatar
maldbwmjr
It's very easy to swap out the shift motor. RockAuto has 2 TC motors: one for $54 and the other for $81. (The link is for the 5.4L). 1999 FORD EXPEDITION Transfer Case Motor
Old Feb 14, 2009 | 09:13 PM
dannielchackas's Avatar
dannielchackas
I replaced the SHIFT MOTOR today, and it quite easy the shift motor's conector will have like 5 but there's also like 6 more for the sensors. they are all numbered.
Old Feb 16, 2009 | 11:22 AM
Warfarin's Avatar
Warfarin
sweet, thanks. Also I was in snow yesterday and found that the AWD doesn't work, I'm guessing because the clutch packs are gone. Will 4Hi and 4Lo still work if it is the shift motor?
Old Feb 16, 2009 | 11:33 AM
alwaysfords41's Avatar
alwaysfords41
How did you test the A4WD? If the shift motor doesn't work none of the 4WD functions will. The typical discussion about clutch packs is the rear end LSD, which won't really play a role in 4wd working or not.
Old Feb 16, 2009 | 05:08 PM
Warfarin's Avatar
Warfarin
I tested it by getting stuck in the snow. Rear wheels were spinning like crazy and front ones just sitting there.
Old Feb 18, 2009 | 07:27 PM
680276122's Avatar
680276122
You are putting the shifter in neutral before you put it into 4H or 4L, correct?
Old Feb 18, 2009 | 07:53 PM
alloro's Avatar
alloro
If you were in 4WD when the motor went then your t-case still in 4WD. If you were not in 4WD then 4WD will not be available until the motor is replaced. Assuming the motor is the problem of course.
Old Feb 18, 2009 | 07:56 PM
alloro's Avatar
alloro
Although you can shift to neutral to do either of these. You only have to be in neutral to shift from 4H into 4L or vice-versa. To shift from 2H (or A4WD) into 4H or vice-versa you can also be either sitting still in gear or moving.
Old Feb 18, 2009 | 08:50 PM
Warfarin's Avatar
Warfarin
I do know about shifting to 4lo in neutral and I have tried shifting to both while in neutral with no effect
Old Feb 20, 2009 | 08:48 PM
Warfarin's Avatar
Warfarin
ok New question. If I was to replace the t-Case could I put a t-case with a 2 hi setting on it, to replace my one with no 2hi setting?
Old Feb 21, 2009 | 07:41 AM
alwaysfords41
I think all you need is a shift motor.
Old Feb 21, 2009 | 09:19 AM
alloro's Avatar
alloro
The t-case isn't the problem, the controls for it are.
