Post your interior pictures
Old Feb 12, 2009 | 09:16 PM
JEEP97TJ's Avatar
JEEP97TJ
I'd like to see some interior pictures of some of these trucks. Anything would be appreciated.
Old Feb 12, 2009 | 10:06 PM
1966Tbird's Avatar
1966Tbird
i'll get some up tomorrow morning, i just ripped out my vinal floors and sprayed bedliner in looks really sharp
Old Feb 12, 2009 | 10:08 PM
JEEP97TJ's Avatar
JEEP97TJ
Nice, I appreciate it.
Old Feb 12, 2009 | 10:19 PM
anojones's Avatar
anojones
"i just ripped out my vinal floors and sprayed bedliner in looks really sharp"
I'm considering doing this in mine, curious about the pictures and how you did it and what you used.
Old Feb 12, 2009 | 10:50 PM
1966Tbird's Avatar
1966Tbird
i used a bedliner kit from ebay, mixed it all together and sprayed with the supplied gun, i made sure to clean the floor pretty good but i wouldn't bother if i did it again that stuff sticks to ANYTHING. but the job couldn't be easier just make sure not to get it wet while it is drying or it will turn to white, then you need to scrub it down with alcohol to get the black color back before it dries and it takes about 2 days to dry completely and one to be able to use it
Old Feb 13, 2009 | 08:51 AM
1966Tbird's Avatar
1966Tbird
here ya go i still need to get floor mats because the bedliner gets dirt from your boots stuck in it
oh there are mats that you need to get off the floor on the floor pans of the drivers side and passengers side where you put your feet i used a grinder with a wire brush and a screwdriver and it did a nice job then i wiped it down with alcohol and a peice of blue foam insulation (from our mushroom houses)
i also did the bed, if you do the bed don't let it sit out side for like 3 days because if it is still tacky at all the rain will turn the bedliner white and you have to use alcohol to get the color back
Old Feb 13, 2009 | 09:14 AM
1966Tbird's Avatar
1966Tbird
i would take a vid for road noise but my fan clutch is going bad so i dont want to run it
Old Feb 13, 2009 | 09:40 AM
deeznuts822's Avatar
deeznuts822
I like where u put the shift pattern for the transfer case.
Old Feb 13, 2009 | 09:48 AM
1966Tbird's Avatar
1966Tbird
thanks i pulled it out of the stock **** and epoxied it there the stock **** would fly off when i shifted
Old Feb 13, 2009 | 10:01 AM
anojones's Avatar
anojones
That looks good. I am a little worried about dirt sticking to the stuff, but my 95 F-250 is for work around the property and hauling- not a daily driver. The interior carpet is in rough shape from the previous owners and seems to have a funky smell I can't get rid of. I'm tempted to pull the headliner too and do that as well, but might be a bit noisy. Just gotta figure out how hard it is to get the seats out.
Old Feb 13, 2009 | 10:14 AM
1966Tbird's Avatar
1966Tbird
the seats come out easily but the belts won't go through the seat and you need a torx bit to get the belts unbolted, it is pretty straight forward just get a set of cheap floor mats at wal-mart or something for dirt sticking to it that's what i am going to do as soon as i get the fan clutch fixed parts come in on tuesday for my nitrous system and the fan clutch so i'll take a vid of the road noise, it increased a little but it's not too bad i like hearing my tires hum
Old Feb 13, 2009 | 12:05 PM
Uncle Tony's Avatar
Uncle Tony
Here's a shot of my 96 F150 Ediie Bauer 2wd. Its the only one I have of the interior ... so far.
And one of my 97 TJ:
Old Feb 13, 2009 | 01:19 PM
JEEP97TJ's Avatar
JEEP97TJ
Nice job on the bedliner, I have the interior of my TJ Herculine'd.
That Eddie Bauer is nice and clean.
Keep 'em coming.
Old Feb 13, 2009 | 06:43 PM
brown 4x4's Avatar
brown 4x4
That Eddie Bauer is very clean. That is my favorite interior color for these trucks.
Here's my 95:
I need to get some taken of my 97's interior. Pretty much the same except it's got the 40/20/40 seat.
Old Feb 13, 2009 | 07:57 PM
1966Tbird's Avatar
1966Tbird
wish i had 3 pedals like all you guys, i have a feeling my aod will explode when i spray it
