Help
Old Feb 12, 2009 | 09:12 PM
bigenough's Avatar
bigenough
Help
Well i got the oil pan sealed ford has a certain type of sealer just for diesel engines, it works great, everything is workin great, but i have a bare breaded ground wire connected to the back of the engine and i cant figure out where it goes help please!!!!!!!!!!! Thanks in advance
Old Feb 12, 2009 | 09:36 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look at the top of the firewall on the passenger side, close to the hood bracket. There is a wire like you mention that is there. I will look for a pic.
Old Feb 12, 2009 | 09:53 PM
JT250's Avatar
JT250
What did you use? Did you have to drop the oil pan all the way? I have a small leak and my book said you have to pull the engine to get the pan off. I am assuming that is not correct. Just wondering if you can get it all the way out without jacking the engine up or pulling it.
Old Feb 13, 2009 | 06:31 AM
F350-6's Avatar
F350-6
Unfortunately your book is correct. You either have to pull the engine, or if you're brave, creative, and a really good welder, remove the structural cross member from the frame and drop the pan that way. You just have to make sure the cross member gets put back correctly.
Edit: There was a thread a while back where someone is selling a 2 piece oil pan that can be installed without doing any of that. You'll have to cut the old pan out and then you could try the 2 piece pan. I don't know if anyone has tried this yet.
Old Feb 13, 2009 | 04:31 PM
bigenough's Avatar
bigenough
oil pan
Wish i could give you better news but you have to atleast raise it, i pulled mine just to straighten out the oil pan and clean up lots of other stuff. The way it is designed you will have to raise it alot which will result in unbolting the turbo. But you can drop the pan about an inch or two and if you can clean it well enough you can seal it that way but the sealer you have to get from the ford house its a type of sylicone and it requires a sylicone gun and its about $20 for the tube.
Old Feb 13, 2009 | 04:34 PM
bigenough's Avatar
bigenough
Thanks for the help i remember taking it off now.
Old Feb 13, 2009 | 07:25 PM
miller_feed
Good deal, glad I could help. Let us know how it holds up.
