Sponsored by: Real Truck
dually bed conversion?
Old Feb 12, 2009 | 06:08 PM
egb34me's Avatar
egb34me
i have a 2001 f350 srw crew cab 7.3 with an 8' bed and i am able to get a dually bed cheap. anyone know how much work is involved in changing the 2 beds and adding the extra dually wheels? mainly wanting to do this just for looks. thanks in advance.
Old Feb 12, 2009 | 07:29 PM
Vijay's Avatar
Vijay
You might want to change the Axel as well. Duallies have dana80...
Old Feb 12, 2009 | 07:39 PM
strokersace's Avatar
strokersace
Where are you located and what color is your truck? I'm contemplating on converting my dually to a SRW. Probably would unless it was a deal I couldn't pass up!! There's 8 torx head bolts that hold the bed into place. They're hard as hell to get loose if they haven't been before!!!
This would be the best way because he's right, the rear axles are completely different. The front axles are the same and all you'd need is the dually adapters for both sides.
Old Feb 12, 2009 | 09:58 PM
egb34me's Avatar
egb34me
located in northern michigan, but the dually bed is practically brand new and it's coming from a good friend so the price is right.
what is the benefit of changing the rear axle? i really want to do this for as cheap as possible without getting too mechanical.
Old Feb 13, 2009 | 01:17 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you don't swap the axle, then you don't gain anything by making the conversion, you would mainly get your gains from going to the ~11" ish ring gear and the larger shafts on the D80. Plus you can't really go deeper than 4.56 on a 10.5", so the larger axle can take a deeper gearing, which is where you get a lot of your pulling power.
As far as the "jsut for looks" bit, I'm not 100% positive the 10.5" Sterling will be able to take a DRW rim without rubbing on the leafs springs. You should get a wheel and try facing it inwards to make sure you won't be hitting anything. Plus, you'll need at least longer studs even if the rim fits to be able to bolt them both in.
Old Feb 13, 2009 | 10:34 AM
strokersace
What he said! If you didn't want to swap axles, you'd have to get some sort of spacer/adaptor for both sides of the rear axle to get the dually rear wheels out far enough. The Dana 80 dually axle is approx. 12" wider than the 10.5" Sterling that you have now. It's specifically designed for the dually. If you just used an adapter on your 10.5" rear end, it would likely put WAY too much stress on the wheel bearings because of the extra lenth and weight hanging out there on the end.
Old Feb 13, 2009 | 11:16 AM
texastech_diesel
Token Redneck
Originally Posted by strokersace
The Dana 80 dually axle is approx. 12" wider than the 10.5" Sterling.
Sweet, you actually have a dually. So the axle is wider? I've always thought that they were, but never being able to actually measure one myself, I was leary about making an **** out of myself on the internet
Old Feb 13, 2009 | 11:27 AM
strokersace
No worries!! That is my best guess as to how much wider they are than a SRW axle but it's got to be close. The front axle on a dually is the same as a SRW except it has adapter on each hub to allow for the offset of the dually rim. The Dana 80 rear axle does not have any adapters, so it is definately wider to compensate for the offset.
Old Feb 13, 2009 | 02:38 PM
egb34me's Avatar
egb34me
thanks for all the input. i'll check into it and see if it's worth it or not.
Big Black Dually
Mar 16, 2017 04:48 AM
Big Black Dually
Mar 9, 2017 09:43 AM
Big Black Dually
Mar 8, 2017 06:11 PM
logangg
17
Jun 28, 2016 06:50 PM
FullMetalJacket23
Feb 25, 2016 02:15 AM
